Question about HP Pavilion Media Center a1330n - AMD Athlon 64 2.4GHz Desktop Computer (Open Box Product, Limited Avai... (EL466AAABAOB)
Won't Turn One
I using my computer one day and it froze up, so i turned it off to restart it. When i restarted it, nothing came on the screen and the alarm was making a constant beeping noise. It isn't just a long beep, it's a bunch of little beeps over and over and it never stops. Nothing comes up on the monitor either it just says no input signal, and then monitor is going to sleep. All the while it the computer seems to be working hard it self, it is really loud and the fans are at full blast. I was told it might be the power supply, i am just not very handy. What should i do?
  • everybody_lo Dec 30, 2008
    turned right on! still slow as hell, but works just as good as before.
    thank you soooooo much!
    Problem Solver:
Try to remove the memory card and clean it together with the memory card slot. then Turn on it again.
Posted on Dec 30, 2008
I have a toshiba c55-a5100 and i decided to update and restart it but it hasn't turned off to actually restart. So I tried to turn it off and then turn it back on. Take the battery out and nothing. It...
It appears to have damaged the operating system, so windows cannot restart. Try pressing F8 before you get to the windows screen, to go into safe mode and use system restore to go back to before the upgrade was done.
Oct 01, 2014 | Computers & Internet
Ipad wont turn on
Hold the lock button in until it restarts and when it does restart it again to make sure it's fine . If the problem persists and it flatly won't turn on you should probably get it checked out .
Dec 27, 2013 | Apple iPad 2
Gateway GT5082 Media Center Computer - Froze. When I turn it on, I get a blank screen and a single, consistent beeping. Once I was able to F8 to restart, but then it happened again and it won't come...
That is a ram problem. Take em out and reseat them, and then one at a time, if more than one.
until something works. then is nothing works, get new ram.
Aug 06, 2011 | Gateway GT5082 PC Desktop
Hi! Computer screen froze when shutting down, I turned it off, turned it back on and now it is stuck on "start up repair" screen, for hours! Help!
Restart it and try start windows normally.
If that doesn't work, try safe mode and restart the computer.
Nov 20, 2010 | Computers & Internet
Laptop has black screen on startup. what do i do to repair this.
I have a similar problem:
I have a Compaq Presario SR2010NX desktop computer. Recently, very occasionally, the computer would freeze and the screen would scramble. It almost looks like someone chopped up the picture on the screen. Then we would have to manually shut down the computer and restart. It would always work fine afterwards.
Yesterday the computer did it again. It restarted fine but when my boyfriend tried to install a new mouse the computer froze again and the screen went scrambled. Well this time it did not start back up. I tried to unplug the computer from the wall and restart but that got me to the COMPAQ screen and then the computer froze again and the word compaq was doubled all the way down the screen. We continued to try to start it in PC recovery but it would get the the program and freeze. I actually got it to run once but I couldn't see what it was doing because the screen was scrambled.
Now we have restarted it so many times that it will start up, light turns green, and stays green. The computer sounds like its starting up and it seems louder than normal. The computer doesn't do anything and the screen is black. The lights on the keyboard do not turn on but the light in the mouse does. The CD drive will light up and run as well but nothing happens after that. I can't see the cursor and the keyboard does not work.
I opened the computer up, cleaned the dust off, tried to re-install my old RAM and that did not work either. I disconnected the CD drive but that did not work. Tried to start the computer with nothing plugged in except mouse, keyboard and monitor and that did not work.
I don't know what to do! Help!
Oct 21, 2010 | Computers & Internet
I have an Asus G1 laptop and I was just on it when the screen froze and an error message appeared saying the display adapters were not working and then the screen went distorted and froze so i reset it ...
Press F8 when you turn on the computer and from the list of options select safe mode and boot into safe mode when you are on the desktop screen go to the device manager ( you can use this path : start-run-devmgmt.msc) in the device manager go to display adaptors right click it and uninstall it.
after that restart the computer.
if this doesnot work again boot to safe mode and try to do a system restore (start-all programs-accesories-accesibility-system tools-system restore)
select a date when your system was working fine, that should fix it.
Mar 10, 2010 | ASUS A8Jm Notebook
Cant reboot - it started when the internet froze and i did ctrl atl delete and ended prosces for expoler, then computer froze so i used ctrl alt delete to restart computer, when computer restarted it...
Good day sir/maam, the reson why it froze is caused by a bad memory module, you may need to replace it. Open up your computer and locate the memory modules, remove all memory modules and bring it to a computer vendor for testing. or if you have the cash, better buy a new one. make sure that what you install on your PC be it tested or new is good.
Sep 27, 2009 | Dell Dimension 2400 PC Desktop
Tom tom 520
go to there web site they are great on helping out.
Jun 07, 2009 | Tomtom GO 520 GPS Receiver
Blue Screen of Death, but not quite
hard drive is a main failure concern, check to ensure power supply is plugged in. sounds like you have a corrupted rgistry file-locate OS for that unit and hit ''repair'', should solve the problem.
Jun 29, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
