Question about Elliott's Car Radio Ford-COSF-18808-E Car Speaker
Radio sound with a noise
I have a Acura Tsx 2004 and When I turn my radio a unusual noise come out of the front speaker. even when the volume is low.
What that could be
Thank You
  • 1 more comment
  • tonyanalfe Dec 30, 2008
    The noise is constant is like a whistle.
    could be and the front speakers are not working.
  • jason May 11, 2010
    like a generating noise ?
    Problem Solver:
  • 8 Answers
Please take out the speaker and inspect it for a torn cone. At times, humidity, amp power or just wear and tear ruins the cone. Then you can replace the speaker or re surface the old speaker with a new cone. That will save you some bucks but may not be as well as buying another speaker. Also please use the same model and Ohms of it. 8 or 16 ohms
Posted on Dec 30, 2008
How do I remove radio center console for 2004 Acura TSX
Could be a bent clip. It has to come off. Get as close as you can to the top clip and pull it loose. You don't want o break the bezel, so one of two things will happen. The clip will bend and come out, or the plastic tab holding the clip will break. Neither is that bad. it will still hold close with the other clips. Breaking the bezel is far worse.
Aug 14, 2015 | 2004 Acura TSX
I have a 2004 Acura TSX and for some reason I cant hear my radio or my navigation. It was working fine and then one day I went through some gravel and it never worked again. the radio display turns on but...
Have you tried to pull the battery for 15 mins and reset the whole car? You'll need the security code for the deck after connecting the battery. It's usually in the owner's manual...
Jan 27, 2015 | 2004 Acura TSX
Volume not working in my 2009 Acura TSX, radio comes on but not volume
you have a short in your radio and need to have it taken out and looked at by a radio shop one of your diodes are fried
Dec 15, 2013 | Acura TSX Cars & Trucks
Radio power is on but no sound coming from speakers/radio on 2005 Acura MDX. Sound works with CD's
Turn on the radio and increase the volume if you can hear a hiss through the speakers, chance is the aerial/antenna connection is not hooked up correctly. Another way to check is try tuning to an AM station if you get a signal on AM but not FM then it is The antenna. You may have to remove the radio to get at the connection.
Oct 05, 2013 | 2004 Acura MDX
Where inside my 2010 acura tsx can I find the radio code to unlock my radio?
Hello,please help me to find radio and CD code for acura TSX 200 JH4CU2F64AC014118 S/N of CD 10002925
Oct 27, 2010 | Car Audio & Video
I have a 2004 acura tsx that i need a radio code for. My battery died and I do not have this code
go see a dealer service departement with vehicle registration at hand they will provide it to you free of charge
Aug 21, 2010 | 2004 Acura TSX
2004 Acura TSX Radio and A/C PROBLEMS
You might have to reset the Radio: Here is how it has to be done without costing you a bunch of money - Every time the battery is disconnected this has to be done: If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
Jul 27, 2010 | 2004 Acura TSX
2004 acura tsx 6cd changer jammed
I CAN HELP YOU GET THE CODE OFF YOUR RADIO NEED TO REMOVE RADIO AND AND WRITE DOWN SER# AND EMAIL ME BACK AND I CAN HAVE YOU A NUMBER YU TYPE INTO RADIO AND IT WILL TURN ON LET ME KNOW
Jun 30, 2008 | Car Audio & Video
Car Audio & Video Logo
96 people viewed this question
Top Elliott's Car Radio Car Audio & Video Experts
xxxxxx xxx
Are you an Elliott's Car Radio Car Audio and Video Expert? Answer questions, earn points and help others
