Question about Minolta Maxxum 800si 35mm SLR Camera
Minolta maxxum 800si flash won't fire
With a new battery, my flash suddenly just won't fire.  The flash ready icon in the view finder doesn't appear either.  Have I somehow made a mistake in one of the settings, or what? Sam
3 Suggested Answers
spotatohead
  • 95 Answers
SOURCE: Minolta Maxxum 400si 35mm SLR Camera manual
Here you go:
http://www.nodevice.com/user_manual/konica_minolta/film_cameras/dynax_500si_maxxum_400si_rz_430si_450si_alpha_303si.html
Posted on Dec 11, 2008
SOURCE: Minolta MAXXUM 3xi the view finder is very dark(bought second hand)
I no the older Minolta's had an aperture problem the pictures when zooming out after they were developed were very dark. But inside and wide angel shots always came out nice I had to have the aperture base plate replaced on my Minolta Maxxum 3000i my point and shooter, I wish this helped but it sounds like something different in your case it also maybe the aperture acting different in your camera than it did in 1 of mines.
Posted on Feb 04, 2009
View finder is dark and fuzzy
It needs to be profecionaly cleaned and cept in a clean inviroment
Nov 29, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
What year was the Minolta Maxxum 7000, serial number 16043985? Thanks, Karla
I do not know for certain. You might find that answer on the Yahoo Minolta groups.
The Maxxum 7000 was introduced to the US market in 1985. Sold as the Alpha 7000 in Japan and Dynax elsewhere, it was replaced by the 7000i in a couple years. Then the 700, the 700xi, the 700si, the 70 and the 7 was the last film based 7 series. There
They also made 8000i, 800si, etc. The 9 series was the Minolta Professional cameras and they had the toughest bodies, weatherproofing, higher shutter speeds, and more.
Later models introduced better autofocus, better exposure options, wireless flash, faster film advance, etc.
lightspiritphotography.com
Nov 10, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Is it bad to keep the lenses attached to your film cameras when storing them for 7 to 8 years in the camera bags thanks Also my Minolta maxxum 500si's view finder is not bright outside in the bright...
it's just okay to store with the lens on the camera, but it's better to have a camera body cap and front and back lens covers on the lenses with cases stored in a dry place with batteries removed from camera.
for the finder i would suggest a soft rubber eye piece accessory that fits on the finder.
Sep 13, 2009 | Minolta Maxxum 500si 35mm SLR Camera
Presetting all buttons and dials
This question is answered for you in the 800si user manual. By pressing the program-reset button, marked with a P top right, this will re-set all camera fuctions, but not red eye reduction-data memory-and ISO setting. To turn on red-eye, press the flash-mode button in the inside of door, turn front or rear dial untill a small "eye" appears in data panel. When selected, the flash will fire a series of small bursts before the main burst, causing the pupils to close slightly, so reducing red-eye. To turn off red-eye, select another flash mode. Resetting all custom fuctions, press and hold the ajust button in door of panel, slide main switch to LOCK then return it to ON.
Feb 01, 2009 | Minolta Maxxum 800si 35mm SLR Camera
Bad Minolta Maxxum lens?
Oddly enough, the camera and lens are working just fine now - or at least they appear to be. I'll shoot some more when I have good lighting and 1-hour them tomorrow for the results.
Nov 24, 2008 | Konica Minolta Maxxum QTsi with 35-80 lens...
Minolta Maxxum 3200i Flash does work
Try to short out the flash and see if the flash flashes.
Remove flash from camera.
New or fresh bateries installed.
Get wire with insulation and remove both end bare to 1/4"
Turn on flash and wait until light turn green or ready.
Touch one lead to center of flash pin, touch other end to the outside(rail on the side) pin.
Flash should discharges.
atdlee@netzero.com
Jul 28, 2008 | Cameras
Minolta Maxxum 7000
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Jul 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
My Minolta Maxxum 3Xi has a dark picture in the view finder. It won't focus on anything because everything in the view finder is dark, if not completely black. I was told it might be the aperture ring. ...
The aperture ring is the right diagnosis. The aperture mechanism has a broken piece that can be repaired by a competent repair shop for under $75. There are no parts available for Konica Minolta cameras since Sony bought them - the part can be rebuilt.
Oct 22, 2006 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Minolta Maxxum 450si - dark images through view finder
The aperture mechanism needs repair - though most parts are no longer available because Sony purchased Minolta, this is a problem that can be repaired by a competent independent repair shop.
Aug 29, 2006 | Minolta Maxxum 400si 35mm SLR Camera
Minolta Maxxum 800si 35mm SLR Camera Logo
37 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
