Question about iLO 3200 32 in. LCD Television
How do i hook up my ILO TV to direct TV satelite?
Ok, see above
I have a ilo 32 in hdmi hdtv and i have mine hook up to direct tv .on the back of the receiver plug your red,white and yellow into the audio 1 of the direct receiver. on the back of your ilo tv plug the other end to the av1 and use S-VIDEO ALSO. plug the sat cord to the ant.in. on the tv set remote hit video and go down to s-video and hit ok. you need to plug all three plugs into their color ans the s-video too in the AUDIO section. mine works great !
Posted on Dec 30, 2008
1996 T100 V6 CHANGE tps, 3 coils ,spark plg,wires, check fuel pressure ,itwill not rev above 3000 rpm??
may be a vacuum hose is rotted out that leads to a device only activated over that limit; or a vacuum device that just fails to maintain good vacuum when it hits that level of demand.
Dec 09, 2013 | 1996 Toyota T100
Philips dvp 3618 unlock region code
1. Power ON the DVD player with no disc inside
2. Go to the SETUP icon and press OK; next, go to
Preferences and press OK
3. With preferences highlighted,
3a. Press NEXT CHAPTER (button above AUDIO, it looks like
this: >'),
3b. Press PREVIOUS CHAPTER (button above SUBTITLE, it looks
like this: '<)
3c. NEXT CHAPTER >'
3d. PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
Mar 10, 2013 | Televison & Video
THE REFRIDGERATOR DOESN'T WORK ABOVE SETTING #3 AND GOES TO 10 DEGREES AT SETTING 3 OR BELOW
heck for good clean and tight fitting connection of thermistor to control board. If this is OK, then a diagnosis of the thermistor resistance to temperature is needed. If it is OK you could have a bad (stuck) relay on the control board.
Nov 22, 2012 | Dometic RM2652 Refrigerator
Unlock code for Philips DVD player dvp3650
Region code hack procedure for DVP3650 1. Power ON the DVD player with no disc inside 2. Go to the SETUP icon and press OK; next, go to Preferences and press OK 3. With preferences highlighted, 3a. Press NEXT CHAPTER (button above AUDIO, it looks like this: >
Sep 12, 2012 | Philips Televison & Video
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a...
Mystery message "wait" appears above "following schedule" display line on our Th8000. Ac does not come on even when temperature is in range. Fan operates ok. Is "wait" setting one I can reset? Maybe a compressor issue rather than thermostat? Thanks
Jun 21, 2010 | Honeywell Electronic Programmable...
Yamaha 2001 ttr 250. Bogs above half speed, under load
I have the same problems with my 1999 TTR 250, were you able to find out anything?
Walt
goalhawk@hotmail.com
May 04, 2010 | 2002 Yamaha TT-R 250
2001 CHEVY SILVERADO 2500HD BATTERY LIGHT FLASHES INTERMITTENTLY. NO PROBLEM WITH BATTERY OR WITH ALTERNATOR, BOTH OF WHICH TEST OK. NO PROBLEM WITH STARTING OR RUNNING, EXCEPT FOR THE FLASHING BATTERY...
2001 chevy silverado 2500hd battery light flashes intermittently. no problem with battery or alterntor. both tested ok. no problems with starting or running. voltage gauge reads just above 14. no problems with anything except battery light flashes. what could be the problem?
Dec 04, 2009 | 2001 Chevrolet Silverado 2500HD
Brake lights do not work. Fuses are ok. Relay fuse is ok. Brake switch unknown
The switch is located above or behind the brake lever/arm above the pad. should be a small push button switch. As you press the pedal the switch pushes out conecting the circuit. You can verify a bad switch by jumping the wires to see if the brakes then work.
Oct 26, 2009 | 1997 GMC Sierra
92 chevy s-10 . the speedometer goes everywhere after u go above
hi when the cable is going you'll get these symptoms pull the cable out and inspect it if the looks ok then pull out the gears and inspect if it's ok then suspect the odometer
Sep 10, 2009 | 1992 Chevrolet S-10
Cannot open drive(E:) others ok
hey i think u have a virus in your pc.otherwise game disc data may be partially corrupted.It happens because in such case the cd runs for some time afterwards .Please check that cd in other pc, if it works then u have a problem in your cd drive...
Ok tell me afterwards you have gone through it.
Apr 10, 2009 | Computers & Internet
iLO 3200 32 in. LCD Television Logo
420 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
