Question about Whirlpool 24 in. ADP5962 Free-standing Dishwasher
My tablet won't dissolve.
I have a problem. my dishwasher is clean however my pots come out as dirty as they went in. my dishwasher heats up from a cold water tap. often i find my tablet at the bottom of the dishwasher at the end of the cycle still intact. my pots are hot from drying but wonder if the whirlpool has two elements for heating? i cannot understand what is going wrong. hope someone can help.
Sounds to me like the dishwasher isn't filling up with cold water. I had a similar problem a few months ago, caused by limescale blocking the inlet and drain valves. Might be worth trying some kettle limescale cleaner solution and putting it inside the machine - and leaving it overnight then trying the machine out with no dishes etc in it.
Posted on May 16, 2007
I went to take out my dishes out of the dishwasher this morning and the tablet was sitting at the bottom of the machine half disolved and most of my dishes weren't washed properly. What is the problem?
1. Check that water enters dishwasher.
2. Check that water is heated,tablet door will then open, this allows the propellor to shoot hot water at tablet to dissolve.
Apr 19, 2011 | Smeg 24 in. DWI612 Built-in Dishwasher
Tablet not dissolving, and dishes dirty
Hi,Nicole, try this:
Run the water nearest the dishwasher (usually the sink), getting the water as hot as possible immediately before starting the dishwasher. This will help getting the tablet to dissolve.
--Best regards, --W/D--
Apr 05, 2011 | Bosch Dishwashers
Hi I've got a diplomat dishwasher but the tablet keeps dropping into the cutlery department and is not dissolving I've tried putting it on the hottest wash puttng the tablet in one of the trays but...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 23, 2010 | Dishwashers
ADG6340 not washing well. Now tablet doesn't dissolve sometimes.
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 14, 2010 | Whirlpool 24 in. ADG6340 Built-in...
Not cleaning pots 100%
Does it still seem to be doing a normal wash except that you have no heat when wash is on.This could be a faulty Heater or Programmer.
Hope this was a help.
Good Luck.
May 09, 2010 | Electrolux 24 in. ESI6220X Free-standing...
Dishwasher cycle runs: tablet is not dissovlved, dishes dirty
If the dry cycle has a problem, check these:
Heating element
Drying fan
Thermostat
Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat.
Aug 29, 2009 | Frigidaire Dishwashers
Tablet not fully dissolving. dishes not clean after wash.
The water is not hot enough. It may be pausing to heat the water and when you open the door it resets and starts again. Check the electric element at the bottom that heats the water to see if it is burnt out.
Jul 22, 2009 | Dishwashers
My Hotpoint Aquarius diswasher won't dissolve the washing tablets
I don't have a solution, but the exact same problem is happening with my dishwasher. Nothing is getting cleaned properly.
Did you manage to get the problem fixed?
Jun 01, 2009 | Dishwashers
Hotpoint dwt 10 dishwasher - the dishwasher tablet is not dissolving and remains in the bottom of the dishwasher after running a load therefore dishes arent cleaned!
I know it sounds strange, but many times when detergent dissolve, a failed heating element is to blame. The detergent needs that water to be hot to dissolve and activate the detergent.
Recommend you check the heating element for obvious damage/failure. When you run the full cycle, does the heating element get hot? If not, replacing it is not as hard as it appears. Post back here with further questions, OK?
If the heating element _is_ working, the other possibility is a failing wash pump motor, but depending on the age of your dishwasher, replacing
May 03, 2009 | Dishwashers
Whirlpool 24 in. ADP5962 Free-standing Dishwasher Logo
131 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
