Question about Canon MV700 Mini DV Digital Camcorder
Canon mv700 camcorder sound but no picture hardly used
Hardly used my camcorder after having it for 4 years. Just played back a couple of tapes i had recorded previously o.k. Then i entered the date, time etc and had a play with the digital effects settings, now i have just sound and no picture. Just a black screen.
Can someone help !!!
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: Gray Lines
What do you mean by "Its only when i go to record or view previous recording"? in what situation doesn't it show the gray lines? What about the viewfinder? do you get lines there aswell? If you don't see the gray lines when you transfer the video out of the camera, then you don't have a head problem, a screen problem maybe. Don't hurry to use cleaner tapes because they can hurt the head, the actual cleaning procedure is one that scrapes the head and leaves some damage. more info please
Posted on Jun 12, 2006
  • 11 Answers
SOURCE: canon mv700 Camera displays an error code
I have one of these. Sounds like you have a fault. Try removing the battery and any tapes. Also you might want to try and replacing the penny size battery it has which keeps the time and date up to date.
When did it last work and what did you last do with it. eg. if you've taken it out of a cold storage such as a loft and then into a warm place you might find that it fails to work because of condensation build up in the internal circuits. Keep it it a warm place for a while and see if it makes any difference.
Posted on Nov 28, 2007
dg9dotorg
  • 151 Answers
SOURCE: black screen when we turn on the camcorder
This is a known issue for this camcorder model, canon will fix it for free. Heres there public announcement:
CCD Image Sensor
It has recently come to our attention that the vendor-supplied CCD image sensor used in this Canon digital camcorder may cause the following malfunction: When the product is used in recording or playback mode, the LCD screen and/or electronic viewfinder may exhibit either a distorted image or no image at all. While reports of this malfunction have been rare in the United States, we have determined that it may occur if the product is exposed to hot and humid environments.
Effective immediately, and regardless of warranty status, Canon will repair, free of charge, products exhibiting the above-mentioned malfunction if the malfunction is caused by the CCD image sensor. Canon will also cover the cost of shipping and handling in connection with this repair.
U.S. residents are kindly directed to contact the Canon Customer Support Center for further assistance at 1-800-828-4040. Support hours are Monday thru Friday - 8:00 AM to 12:00 midnight; and Saturday 10:00 AM to 8:00 PM (all times EST). Alternatively, if electronic support is preferred, please send your email to carecenter@cits.canon.com
This information is for residents of the United States of America and Puerto Rico only. If you do not reside in the USA or Puerto Rico, please contact the Canon Customer Support Center in your region.
We sincerely apologize for any inconvenience caused by this issue, and appreciate your understanding in this matter. Thank you for your support and patronage of Canon products.
Posted on Dec 11, 2007
SOURCE: Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Posted on Jan 09, 2008
  • 73 Answers
SOURCE: playback mal-function
TRY A CLEANING CASSETTE THIS MIGHT PROLONG THE AGONY. HEAD IS DIRTY OR NEEDS AJUSTED
Posted on Mar 02, 2008
How can I connect my Canon Camcorder MV700 to my computer Acer aspire L3600 ?
Please refer page 118 of the manual of Cannon MV700 available from this website.
http://files.canon-europe.com/files/soft24377/manual/MV690_MV700_Series_CUG_EN.pdf
You can connect camcorder with Acer Aspire using a USB port and cable.
But this interface only allows transfer of still images from the SD card on the camera. It will not allow video images to be transferred from the tape.
Some models of Acer also have flywire interface (IEEE1394) and also SD card reader. You can use these also to download video images from the camcorder.
May 07, 2014 | Canon MV700 Mini DV Digital Camcorder
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
How to convert dv tape from Canon ZR20 to MY COMPUTER hard drive?
To transfer video off your minidv cassettes from your camcorder you would need to have a firewire connection to your PC. Either a 4 to 4 pin connection (laptop) or a 4 to 6 pin (desk top computer). USB is used only for picture still transfer. Here are the steps;
1. Plug your mini Dv camcorder into an outlet
2. Plug in you firewire connection into your computer, then plug the other end into your camcorder.
3. Turn on your camcorder and switch your camcorder to Play/VCR
4. Select the software that you want use to do the transfer. Windows Movie Maker is the most assessable software since you have XP on your computer
5. Name your file
6. Select capture from video device (automatically will allow you to save the entire tape and manually would allow you to capture parts of the tape).
Those are the basic steps in some detail. You can save your file from there or you can go on to edit.
Jan 02, 2009 | Canon ZR20 Mini DV Digital Camcorder
Pixels instea of clear picture
The problem is with the tape...Never rewind tape in the play mode for some reason it will screw it up.
And only use good tape such as...
Panasonic - MiniDV Digital Video Cassettes Model: AY-DVM80XJ
Dec 01, 2008 | Canon XL1S Mini DV Digital Camcorder
Loss of live viewing
Can u tell me model number n make of ur camcorder?
Jun 07, 2008 | Canon Video Cameras
Canon mv700 Camera displays an error code
Nov 27, 2007 | Canon MV700 Mini DV Digital Camcorder
Canon MiniDV mv700i audio problem
A mechanical problem! The tension regulator belt is not well aligned, you need pro fix to do the alignment.
Sep 13, 2007 | Canon MV700 Mini DV Digital Camcorder
Canon mv700 not loading tape
if you hear the cylinder drum running to fast try take out the connection of the drum at the circuit and back it again...try this in you can open your camera....
Aug 08, 2007 | Canon MV700 Mini DV Digital Camcorder
Problem capturing footage from Canon MV700 DV camcorder to Windows XP
I use Pinnacle Studio versions 9 and 10 without any problems. The software sees the camera MV700i and controlls the playback etc. Have also used Ulead Movie Factory without any problems, but its a little harder when it comes to editing the output.
Jun 19, 2007 | Canon MV700 Mini DV Digital Camcorder
Problem with sound during playback
do not used that cleaning cassette it will ruin your video head...cause the cleaner is very rough....just forward a blank new tape for cleaning...the problem of your camera is the tape alignment...
Jul 24, 2006 | Panasonic NV-DS29B Mini DV Digital...
Canon MV700 Mini DV Digital Camcorder Logo
51 people viewed this question
Top Canon Video Cameras Experts
KellySD
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
