Question about Toshiba Satellite M45-S2652 Notebook
DVD-CD Drive keeps opening itself
I have a Toshiba Satellite L350-170 laptop which is approx 2 months old and, what started off as a very intermittant fault, has now effected in the DVD-CD drive tray not staying shut, even when I put a disc in
  • wallyandeve Dec 31, 2008
    my toshiba laptop d drive keep opening, wont stop, help?
  • Dan rogers
    Dan rogers May 11, 2010
    sounds like it needs to go back to the factory
    President:
  • 2,110 Answers
This is due to the motor fault..you have to take it to service center as it is under warranty..
Posted on Dec 31, 2008
How to remove the cd/dvd r drive out of a toshiba satellite a305-s6872 cd/dvd drives
Open the RAM (memory module) lid cover, there should be 2 bolt.
Under the lid cover there is 1 bolt to the dvd/cd drives. loosen it up
akee_akee@live.com
Aug 16, 2011 | Toshiba Satellite Laptop
Computer does not recognise CD/DVD drive
In your device manager have you tried uninstalling and reinstalling the driver/firmware
Thanks,
Lee
Jul 04, 2008 | Toshiba Satellite A100-S8111TD Notebook
Where is the location & how to remove the hard drive for toshiba satelite P15-S470
The hard drive is located under the CD/DVD drive. Before you start taking apart the laptop, remove the battery and unplug the AC power.
1. You have to remove the CD/DVD drive. Turn the laptop over. Remove one screw right above the dive and slide the drive out of the laptop.
2. When the CD/DVD drive is removed, you'll see a metal plate. The metal plate is secured by 4 screws. Remove them and lift up the plate from the bay. The hard drive is located right under the plate.
3. After you remove the plate, you'll see the hard drive. The hard drive also secured by 4 screws. Remove the screws, slide the hard dire to disconnect it from the connector on the moterboard and lift it up.
4. You have to transfer the brackets from the old hard drive to a new hard drive. Also, if there is a foil shielding around the old hard drive, you'll have to transfer it to a new hard drive too.
Below is website with a picture guide on how to remove the hard drive>>>>
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Regards.
Apr 21, 2011 | Toshiba Satellite P15-S470...
How to reset my dell inspiron to factory settings as it keeps restarting itself
Do you have problems with a Dell inspiron or with a Toshiba Sattelite?
You'll have to use the CD/DVD that was shipped with your laptop.
Put it in your drive and boot up with it.
Some models have a recovery program and you'll have to burn the CD or DVD first.
Sep 22, 2010 | Toshiba Satellite P105-S6207 Laptop
How do I remove my hard drive from my Toshiba Satellite R15-S829?
READ THIS ALL THE WAY THROUGH. REMOVE THE BATTERY AND POWER BEFORE ANY WORK IS DONE. HAVE ALREADY BACKED UP ALL YOUR DATA.
Toshiba Support Site warns not to try this at home.
User's Manual does not list HD removal.
That being said.....
this is the instructions for a P15-S479, but may be what you need.
Instructions:
2. When the CD/DVD drive is removed, you’ll see a metal plate. The metal plate is secured by 4 screws. Remove them and lift up the plate from the bay. The hard drive is located right under the plate.
3. After you remove the plate, you’ll see the hard drive. The hard drive also secured by 4 screws. Remove the screws, slide the hard dire to disconnect it from the connector on the moterboard and lift it up.
4. You have to transfer the brackets from the old hard drive to a new hard drive. Also, if there is a foil shielding around the old hard drive, you’ll have to transfer it to a new hard drive too.
Here’s a disassembly guide with pictures: Toshiba Satellite P10/P15 laptops. How to remove the hard drive.
Remember the precautions and warranty information from Toshiba before you start. Try to have someone who is really into laptops before you begin
Good luck
ps: Other laptops have their HD's under the keyboard, or in a removable door on the bottom.
Feb 15, 2010 | Computers & Internet
Toshiba Satellite A215-S4747 DVD/CD crash?
Normally when this happens, what one should look out for is the possibility of it happening again. Like desktops peripherals such as disc drives would have connections internally. If you can have them checked out if there were loose connections. It could also be faulty internals that will break down soon such as ICs in the drive.
Sep 11, 2009 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite A200-1M4 When I start my laptop i can hear a long peep sound and my DVD ROM auto opening. My DVD ROM PC detect but It can not read the CD always showing inset the CD. Please help me in...
dvd burners or rom drive have 2 lens inside, one for DVD read, the other for cd read. I see it often where one fails out in the drive but the other works. With one working fine and the other not, I would replace the drive. If still under warranty send it to manufacturer. If not do a search on Ebay for a replacement drive, or get a local laptop repair shop to do it for you.
May 11, 2009 | Toshiba Satellite A200-16J01D Notebook
DVD ROM Keeps on ejecting
Common problem with satellites. It's a hardware issue in most cases with the motherboard.
Apr 21, 2009 | Toshiba Satellite A105 Notebook
I cannot open my Toshiba Satellite 2805 S301 DVD-ROM drive.
Hi Packman,
right click the DVD drive, an choose "push it open" -> direct translated from Danish :-)
. but I´m sure you´ll find it.
regards
/Teis
Dec 16, 2008 | Toshiba Satellite 2805-S301 Notebook
CD sound is no good
try removing the digital setting , IN XP
right click on my computer /manage
device manager
open dvd/cd rom device
right click on cd /properties
click on properties tab
remove check for enable digital cd audio
Apr 13, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite M45-S2652 Notebook Logo
702 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
