Question about Microsoft Xbox 360 Console
4 red lights flashing
When i turn on the console the light is green but after a few seconds all 4 lights start to flash. wat can i do?
  • Anonymous Jan 03, 2009
    when i turn the xbox 360 on 4 red flashing lights appear and i can't play anything
  • 395 Answers
CAUSE This issue may occur for one of the following reasons: The audio-visual (AV) cab... loadTOCNode(1, 'cause'); This issue may occur for one of the following reasons:
  • The audio-visual (AV) cable is not connected correctly or is not plugged in to your Xbox 360 console.
  • The console is not detecting the cable.
This issue does not occur if the AV cable is plugged incorrectly in to a television, stereo, or VCR.
Note This issue occurs only on Xbox 360 consoles that do not have a High Definition Multimedia Interface (HDMI) AV port
Posted on Dec 30, 2008
  • Bernie Reeves Dec 30, 2008
    Here are some things that you can try to fix the issue or to determine what the cause is. If you cannot fix the problem yourself, please contact Xbox Customer Support. Visit http://www.xbox.com/support/contact http://www.xbox.com/support/contact) for information about how to do this.
    Make sure that the AV cable is connected correctly to your Xbox 360 console. To do this, disconnect the AV cable from your Xbox 360 console, and then firmly reconnect the AV cable to your Xbox 360 console.
    Note When you plug the AV cable in to your Xbox 360 console, the cable meets slight resistance before it is fully inserted. If you do not fully insert the cable, all four lights will flash on the Ring of Light, or no video may be displayed on the screen. You know that the cable is fully inserted when the largest part of the connector is almost touching the case of the console.
    For more information about how to connect the AV cable to your Xbox 360 console, click the following article numbers to view the articles in the Microsoft Knowledge Base:
    906144 http://support.microsoft.com/kb/906144/ ) How to connect your Xbox 360 console to your TV or monitor using an Xbox 360 Composite AV Cable
    906303 http://support.microsoft.com/kb/906303/ ) How to connect your Xbox 360 console to a TV or monitor using an Xbox 360 Component HD AV Cable
    906202 http://support.microsoft.com/kb/906202/ ) How to connect your Xbox 360 console to your TV or monitor using an Xbox 360 VGA HD AV Cable
    906203 http://support.microsoft.com/kb/906203/ ) How to connect your Xbox 360 console to your TV or monitor using an Xbox 360 S-Video AV Cable
    Back to the top
    Check to make sure that the AV cable is clean
    loadTOCNode(2, 'whattotry');
    If four red lights continue to flash, unplug the AV cable from the back of your console. Then, try wiping the metal area of the AV cable that plugs into the console. Do this by using a dry, soft, clean, chemical-free cloth. The metal area of the cable is the end that plugs into the console. Clean and wipe the metal area thoroughly, and then plug in the AV cable again.
    Back to the top
    Try another AV cable
    If the AV cable is connected correctly but the four red lights are still flashing, try using a different AV cable if you have one available.
Thats a crock of ****, i have three a/v cables in different rooms so i dont have to lug everything around and they all work with my 360
Posted on Feb 18, 2009
    Problem Solver:
  • 18 Answers
Four rings of death means there something wrong with the av cable.
three rings means there is something wrong with the cpu and gpu.
two rings of death mean the console has been overheated and must be switched off and left to cool.
one ring means there is a major hardware failure.
Posted on Jan 31, 2009
  • jessy bitwa
    jessy bitwa Feb 02, 2009
    also each xbox 360 comes with it's own av cable. Each av cable has it's own encoder chip that only works for the xbox you got it with.
Rings of death is a easy fix.
it involves removeing the heatsinks replacing the heatsink compound and rebolting the down.
there are some other fourms with the full instructions for this.
it works 100%
Posted on Jan 10, 2009
    Problem Solver:
  • 6 Answers
You need to contact xbox 360 customer support, and they'll send you information on how to send it back to them (If you have a warranty) They'll fix it, and send it back for free.
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3's power light goes from green to yellow and then to red and then swithchs off? anyone with any ideas wats wrong? many thanks
ps3 . when i turn it on the green light comes on then goes flashes yellow then goes red and will not come on
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Light flashes between red and green on ps 2 slimline
they just set the light it all right as long as it work
Aug 23, 2009 | Sony PlayStation 2 Slimline Console
My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Red flashing lights, will not completely start up
Do you have a windows XP cd?
If so you can try booting from the cd and running recovery console.
from recovery console type chkdsk -r
This should repair any bad sectors on your drive, allowing the drive to boot
(this scan may take some time)
Jan 23, 2009 | Compaq Presario 5000 PC Desktop
Microsoft Xbox 360 Console Logo
341 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
