Question about Brother MFC-8460N All-In-One Printer
Need to reset 'Drum near end' warning on Brother MFC-8460N.
My Brother MFC-8460N 3 in 1 printer keeps showing 'Drum Near End' how do I reset this?
  • Anonymous Mar 10, 2009
    Still shows Drum Near End after replacing the drum.
    Sniper:
  • 56 Answers
Open the front door
Press clear
then press 1
Posted on Jan 15, 2009
  • 2 more comments
  • John Tuminaro
    John Tuminaro Jan 15, 2009
    Open the front door
    Press clear
    then press 1
  • mrs_realesta
    mrs_realesta Mar 20, 2012
    thx alot, it worked!!!
  • Ron Ozment Feb 16, 2014
    There is no 1 on the 2280sw all in one as there is no keypad. any other suggestions? Thank you for your effort
  • John Tuminaro
    John Tuminaro Feb 17, 2014
    Press Menu 6 0 1 1
  • 8 Answers
  • Este mensaje aparecerá cuando la unidad de tambor está cerca del final de su ciclo de vida.  Utilice la unidad de tambor hasta que tenga una muy mala calidad de impresión, luego reemplace la unidad de tambor con una nueva.
  • Este mensaje continuará apareciendo si el contador de tambor no fue reiniciado al usted reemplazar el tambor.
Para reiniciar el contador del tambor, siga estas instrucciones:
  1. Abra la cubierta delantera.
  2. Presione la tecla Clear/Back.
  3. Presione 1 para reiniciarlo.
  4. Cierre la cubierta delantera, presionando firmemente ambos lados hasta que encajen debidamente.
  • This message will show when the drum is close to the life end. Replace the drum with a new one.
  • The message will continue showing if the countar was not reset when you replace the drum.
To reset the drum follow the next steps:
  1. Open the front cover
  2. Press Clear/Back button
  3. Press 1
  4. Close the front cover.
Posted on Jun 12, 2009
Stop sending fax always give me busy or no respons ng: poor line condition / out of memory
Posted on Aug 17, 2010
How can i reset this printer
Posted on Dec 01, 2010
  • John Tuminaro
    Press Menu 6 0 1 1
2 Suggested Answers
timeattack
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
Posted on Feb 06, 2009
I just installed a new drum and toner cartrideg last week and the error message says drum is near end. Should the toner cartride be replaced?
After replacing the drum and toner you may need to reset the drum life of the machine. This is how to reset the drum life:
Open the front cover where the drum and toner are located. Press the clear/back key. Lcd should show Replace Drum? Then press 1 for yes. Lcd should show accepted. Close the front cover the press stop/exit. Lcd now should show the date and time.
Hope this helps. Rate if it works. Thanks
May 02, 2011 | Brother MFC-8460N Laser Printer
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
I get the code "Drum near end" although the Drum is brand new.
open the front cover and press the clear back button then select the yes option to screen menu
Aug 18, 2010 | Brother MFC-8460N All-In-One Printer
How do you get rid of drum near end after you have installed a new drum on a brother MFC 8860 DN?
Responsibly recycle it -- one company (Office Depot) even offers you store-credit if you take it to them for recycling.
Jun 23, 2010 | Brother MFC-8460N Laser Printer
Factory reset a brother MFC-8460N printer mfp
Looks like <0> followed by <3> will let you input your fax number, phone number and company name. When you need letters instead of numbers experiment with the keypad. For example to input the letter "c" press the <2> three times. To input the letter "h" press the <4> key twice. You will get the hang of this easily.
Dec 29, 2009 | Brother MFC-8460N All-In-One Printer
What does it mean when it says Drum near end
It means the drum has nearly reached the end of it's useful life, just a warning before it says it is all used up. If quality is still good you can open the front door and press the menu or options key and tell it it's a new drum and keep printing until the print quality fades.
Oct 26, 2009 | Brother MFC-8870dw Wireless Multifunction...
MFC-8460N Drum Changed - cannot clear DRUM NEAR END message
This sometimes happen when you dont use genuine cartridges/drums, you can leave it flash just let everyone know to watch for changes in print quality since you will no longer have a warning for this drum. when its near its end.
Feb 24, 2009 | Brother MFC-8460N All-In-One Printer
Close the over
Jul 12, 2008 | Brother MFC-8460N All-In-One Printer
Drum is near end
some packaging is still on drum probally.
check that out and to clear message u need to open all the front covers then hit the clear/back button and then hit number 1 and your set
Mar 17, 2008 | Brother MFC-8460N Laser Printer
Brother MFC-8460N All-In-One Printer Logo
23,348 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
