Question about MSI MS-1012 Notebook
No battery charging instructions for my MSI Wind 6 cell battery, the battery lasts 3 hours. Please can you give me the correct charging instructions for the battery as there was no manual with the MSI when I received it brand new from Ebuyer.
Nurvo tablet will not turn on or off
Have you charged the battery? Please charge it at least for 2 hours, and then try this:
1. Unplug the AC adapter,
2. Remove the battery,
3. Press the power button and hold it for 15 seconds,
4. Install the battery,
5. Plug in the ac adapter,
6. Turn on the laptop.
If it does not work, then probably the motherboard is dead.
Mar 04, 2014 | MSI Computers & Internet
My msi u100 starts up but then the battery light goes red and shuts down how can i fix it
HI Cws666, try to charge your computer for a full 3 - 5 hours without interruptingit, than try again.
If that doesn't work, try buying a new battery.
If that doesn't work send it to computer's brand labs.
Jun 08, 2011 | MSI Wind U100-280US Netbook
I won an msi wind u130 in a raffle. the box says battery lasts for 7 hours, but when i charged it, it lasts only 2.5 hours. Is there any setting i should change to get the 7 hours?
Welcome to the world of unreal advertising. 3 hours is a realistic max.
You could change the sound to off, the screen to dim, the internet wifi off, etc. to get better battery but of course, that would limit the system.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Jim
Oct 03, 2010 | MSI U130416US Netbook
How long do you charge a new battery?
Hi they recomend charge it for at least 6 hours this will give it a full charge, its best if you let the battery go totally flat before you charge it as doing this prevents the battery getting bad cells and will keep it lasting a lot longer.
charge it for 6 hours the first time but it will only usually take 3 or 4 hours to give it a full charge.
i hope this has been some help to you.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts ,thanks
Sep 11, 2010 | Peg Perego John Deere Gator HPX Ride on...
MSI Wind u100 - battery LED flashing red
check for an update with windows 7 then go online to asus support or call them. They should have a solution for you.
May 12, 2010 | MSI Wind U100-053US 10-Inch Mini Laptop
My MSI Wind battery blinked out and not it is blinking orange what does that mean?
The blinking battery light indicates the battery has an internal short which is preventing it from charging. The problem usually goes back to the charge monitor circuit in the battery. There is a thermal fuse that blows if the battery pack gets to hot during a charging cycle to prevent the battery from exploding like to hear about on the internet from time to time. After the fuse blows the only thing to do is get a replacement battery pack.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 18, 2010 | MSI WIND U100 Notebook
My msi won't turn on. Battery is in, charged, and
Try unplugging it and removing the battery. Wait a few minutes. Yes actual minutes. Then put the battery back in and try again.
When you get back in try rolling back to a restore point when you know things were working well.
Could be a software update of some kind threw things out of whack.
Aug 11, 2009 | MSI Wind U100-004US Notebook
MSI MS-1012 Notebook Logo
108 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
