Question about HP Photosmart 945 Digital Camera
HP 945 I need help! When I put batteries (rechargable) in my camera it doesn't do anything except...the viewing screen flashes and I get a red light flashing too. Has anyone ever had this problem?
I had this same problem and I though my camera was shot and gone forever. I even was about to buy another camera after much research, but then I thought I'd try one last time and found out how to do the resetting (taking out the batteries for ten minutes and putting them back in). Well, my HP 945 is now in working order again, and I am thrilled. Lisa WV
Posted on Jul 13, 2007
I have had this problem with my 945 as well, the only way I could get it to stop was to take the batteries out and leave them out for a while.
Posted on Jun 02, 2007
I was taking pictures and the camera just shut off. I thought it may be the batteries, so I put new batteries in and it came on but now will not shut off. The lens is extended and the red light comes on...
I have the same problem. If you get a solution please let me know at corsica2001@shaw.ca thanks! It just happened today! Seems all the hp 945's are burning out at the same time!
Oct 12, 2011 | HP Photosmart 945 Digital Camera
HP Photosmart 945 Digital... Problem
Remove the batteries and SD card for about 5 minutes. Reinsert and see if that resolves the issue..
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Hp 945 frosen with red light on
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
Red light continually flashes, and won't take picture
Set the camera to anything except no flash. Turn it off. Take out the battery. Wait 5-10 seconds. Put the battery back in. The flash should now work until you turn the camera off again (and then you must remove/replace the battery to get the flash working again).
The flash requires some kind of "master reset" to work. Haven't found a permanent solution to this.
Mar 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Flashing Light
I have had a HP Photosmart 945 for a few years now. A few days ago was the first time I saw my camera experience the problem described above. I thought something is wrong with the on-bard logic.
Replacing my batteries (4x2300mAh NiMH AAs) with four other freshly charged batteries of the same kind didn't fix it. The camera's LCD kept flashing on and off for almost an hour until my family got tired of it and turned it off by removing the batteries.
I just replaced the rechargeable batteries with four regular alkaline batteries and now suddenly it works. Go figure.
The moral is that changing the batteries sometimes helps. When it works, it will get your camera going for a while. The problem, however, doesn't seem to be battery-related or I would have seen it a long time ago with smaller-capacity batteries like alkaline AAs. Something is very wrong with the camera itself, that much is clear.
Best-case scenario now is that I have an unreliable camera that can give out at any moment. For example today it died in mid-shot and almost spoiled a family event. For me the solution was "get a non-HP camera".
I hope this helps someone out there.
Dec 19, 2007 | HP Photosmart 945 Digital Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Camera won't work
HP technical Support is the 1st place to go - in case there is a repair/replacement solution. If the camera is over a year old - an economical repair is unlikely
Jul 09, 2007 | HP Photosmart 945 Digital Camera
Errors on the HP 945
If this happened only once...recharge the batteries and forget about it.
Aug 30, 2005 | HP Photosmart 945 Digital Camera
HP Photosmart 945 Digital Camera Logo
283 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
