Question about Orion SpaceProbe 130ST EQ Telescope
Telescope view I have just purchased a celestron eq130 md when i look through the viewfinder i can see the planet but also the four cross members that hold the secondry mirror any ideas Thankyou
  • 3,186 Answers
It's not in focus--- turn the focus knob slowly in and then out until you get a sharp image....... use the lowest magnification eyepiece first-- that's the one with the LARGEST number written on it.
Posted on Jan 04, 2009
When using telescope for the first time (looking at venus) it would not focus, also the cross at the front of the tube was most prominent.
Do stars appear as small pinpoints in your scope? If not then it sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
With the telescope pointed at the distant object, focus the telescope until the object is sharp and clear. The object might appear upside down -- that's normal for many astronomical telescopes. When you have achieved a sharp focus, leave the focus control alone until you are outside at night under the stars.
The focus should now be fairly close for viewing stars and planets. Small adjustments of the focus control may still be necessary for the sharpest view.
Venus is sometimes a difficult object. It is often fairly low in the sky where the atmosphere is most likely to blur the view. Find a bright star and focus it to a pinpoint, then swing your scope toward Venus.
- Jeff
Dec 27, 2016 | Celestron Optics
I use a celestron astromaster 130 eq. When I focus on an object such as a planet at night, the silhouette of the secondary mirror and its mounts overlays the image of the planet. I do not experience this...
You need to collimate your telescope. This site has a really easy to understand diagram and instructions. Hope this helps. http://www.astro-baby.com/collimation/astro%20babys%20collimation%20guide.htm Good luck. Astronomyforums.net and cloudynights.com are two really good sites for information.
Sep 03, 2012 | Celestron AstroMaster 130EQ Telescope
Am I supposed to see the cross in the centre of image on celestron 76eq
You will see diffrection spikes when focused on a very bright object
http://www.goldastro.com/images/newtonian.jpg
and this can also appear around a bright planet. However it is very irritating, and to minimise it, make sure your scope is well collimated (optically aligned).
There is too much to collimation to include here, but there are many guides on the Net
http://www.cloudynights.com/documents/primer.pdf
http://www.atmsite.org/contrib/Carlin/collimation/
Feb 22, 2012 | Celestron FirstScope 76EQ (180 x 76mm)...
How do you use this telescope?
You point the axis of the scope to the star Polaris and polar align it-- then you put the eyepiece into the focuser. Your best bet is to locate a local astronomy club, the members will help you learn how to use the telescope.
A manual can be found on the Celestron web site here:
http://www.celestron.com/c3/downloads.php
Sep 11, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
I can't see anything out of the large scope
Use the 20mm to view an object (building, tree etc.) far away during the daytime. Align the finderscope to the object.
To view the moon, leave the scope out to equalize the temperature for at least 1/2 hour. Use the 20mm and no barlow. Point the scope towards the moon by sighting along the barrel of the scope, then use the finder to zero in on the moon. You may then switch to the 4mm eyepiece. for a more magnified view of the moon. You will have to keep moving the telescope because of the earth's rotation. The higher the magnification, the more you will have to adjust the scope. Because of the cheap finderscope, finding the planets will be difficult. Best to always sight down the length of the scope to get you close. The planets will be small and indistinct.
This is not a astronomical telescope! May be used for views of the moon but the cheap mount is not suitable for other planets. Max power would be 225x NOT 420x as advertised. The erecting prism is for terrestrial use only.
Nothing discourages an amateur astronomer more than a toy store telescope. My advise would be to use this scope for nature watching and go buy a good telescope (Meade, Celestron, Orion etc.). Even Those 60mm refractors are superior to this! A descent scope would cost a minimum of $200
Nov 03, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
When viewing venus or other stars there a black spot in the center of the object. It appears to be the 2nd mirror refleting to the main miror. what have I done incorrect?
You are NOT in focus. Turn the focus knob a little until you see a perfect "disk" for the planet. Stars are always POINTS of light, with a telescope or without a telescope.
Aug 28, 2010 | Celestron NexStar 114GT (269 x 114mm)...
What level magnification do I use to see jupiter or saturn in a telescope?
Your 3.5 inch telescope has a maximum magnification of about 170 power.
This is under perfect sky conditions and a perfectly collimated telescope. Galileo used 30 power magnification to see Saturn's rings and the moons of Jupiter!
Put the eyepiece with the largest number written on it into the focuser do not use the 2x barlow if you have one.
Point it at Saturn. You will see the rings. However they are almost slanted directly toward Earth right now. You will only see a thin line going across the planet.
By the end of 2010 they should open up again enough to make out the "ring" shape.
You only need about 50-70 power to view Jupiter or Saturn, or Venus. Mars is smaller and about 100 power to 120 power should permit you to see the disk of the planet (but it's still very small in the eyepiece).
Dec 29, 2009 | Celestron PowerSeeker 114 EQ Telescope
CELESTRON 127EQ faulty magnification
It won't increase viewing power by hundreds of time but it should be able to show you a close up view of the moon and planets where they look closer (or with the moon, parts of it look closer). When you say it looks further away, something is quite wrong as you know. It sounds like the eye piece is backwards in the mount? Can't imagine what else would make it smaller. Also can't imagine you could even get it in backwards. I have a scope by Meade that is essentially the same Newtonian design. Best of luck.
Dec 31, 2008 | Celestron PowerSeeker 114 EQ Telescope
Obscured view through telescope
You can slow down dew forming on the mirror by NOT pointing the telescope toward the sky during cool-down-- just leave it parallel to the ground. Same goes for your eyepieces -- leave them covered, or inside a case.
Dec 26, 2008 | Celestron AstroMaster 130EQ Telescope
Seben 150-1400 telescope
This is a pretty generic Chinese made 6" Newtonian reflector. The one's I have sampled produce excellent images. Celestron has a great online archieve of its manuals. This scope is similar to their C150-HD Newtonian Model #31056. The manual can be found here:
http://downloads.celestron.com/Manuals/telescopes/c150hd_g8n/c150hd_g8n_manual/c150hd_g8n_manual_0802.pdf
Google "beginning astronomy" and you'll get a quartr of million hits. Good over view here.
http://library.thinkquest.org/29033/frames.htm
and here:
http://www.skyandtelescope.com/howto/basics/3304616.html?page=1&c=y
While you are there get a subscription to Sky and Telescope or their other publication aimed at beginners, Night Sky.
Find a local astronomy club and join it.
HTH, George
Jan 22, 2008 | Optics
Orion SpaceProbe 130ST EQ Telescope Logo
106 people viewed this question
Top Orion Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
deton8 von Splosion
Tony Parsons
Tony Parsons
Are you an Orion Optic Expert? Answer questions, earn points and help others
