Question about Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20G Naga III showing horizontal and vertical lines
I have had a problem with my Naga III X20G LCD. The problem is this, when i move the mouse at the left side of panel a large vertical line goes all across the panel from top to bottom, and when i move the mouse over ther vertical line (a 5cm wide) new horizontal lines come acoss all the monitors, however when i move out the mouse cursor from that part the lines dissapear, sometimes when i load a program like excel or word the vertical lines comes up without moving the mouse. I have noticed also that when i place the mouse cursor over the vertical line, it takes a little (about 200ms) to show up the horizontal line, weird huhg? Anyway a friend who is a technician told me the problem is with the LCD graphic card (i didnt know LCD had graphic card), so my question is, is there a way to fix this? which part or component do i need to replace to make it work? Also another question, the LCD have some scracths on the panel, and I saw some of those iclear from Apple to remove scratchs from LCD's, will this help me to really remove the scraths?
    Champion:
  • 293 Answers
Hi...there,
Yeah, there it... It's called a AD board. It that piece of component were you plugged your VGA or DVI cables to it. Panel scratchs repair kits, not recommended. Beside your panel could be already damaged by this problems you had. Replacing the AD board gonna cost you though...any where from $70.00 or more... My recommendation, just get a new one...saved you the headached and $$$.
Have a nice day!
Posted on Oct 03, 2008
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X22 Naga Will not power up.
Start looking at the power supply for bad caps, see some example of a couple yeras old monitors that failed due to cheap caps being used: http://s807.photobucket.com/home/budm/allalbums
Jan 08, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
FIXED!
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
I’m happy to help further over the phone at https://www.6ya.com/expert/paul_0af9b1d5c0eb4fc3
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20
reinstall your video card drivers ,
Nov 16, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Replacing Sceptre Power supply
The attached pictures are the back of our TV which is a Sceptre X30SV NAGA III. In ours the power supply is inside the vertical panel on the back right of the TV. The plug goes in the bottom of the panel and you remove the panel with the horizontal louvers with 4 screws to get at the power supply. A replacement power supply is from Delta Electronics part number ADP 180CB B , 24 Volts 7.5 amps 180 Watts that we reordered from here:
http://cgi.ebay.com/Delta-ADP-180CB-B-24V-7-5A-180W-4-Pin-Din_W0QQitemZ160268090373QQcmdZViewItem
Aug 23, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
May 22, 2007 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
264 people viewed this question
Top Sceptre Computers & Internet Experts
Ben Slimene Aymen
Ben Slimene Aymen
Arnie Burke
Arnie Burke
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
