Question about Verizon Communications HTC XV6800 Cell Phone - Blue
I get incoming call notification, vibration, but NO RING???
XV6800 from Verizon. Everything seems to be set correctly and incoming call notification is not a problem. It vibrates (when set to vibrate/ring) and the ring tone is a standard that came with the phone BUT it does not ring. Other system sounds work...
  • tsaleh Jan 08, 2009
    I have the same issue, only a cold restart (hard reboot) fixes the issue; then it will happen again after a day or two? Is this a nv memory issue where the configuration is lost? When the battery power drops below certain threshold?
  • Anonymous Apr 20, 2009
    My phone worked fine for a year, but now when I get an incoming phone call it will not ring. I can get it to vibrate, but not ring. Even a soft or hard reboot does not fix this.
  • 3 Answers
SOURCE: No Vibrate
Go to menu, tools, sound settings, call sounds, then click on call vibrate. click on. click ok.
Posted on Sep 23, 2007
  • 99 Answers
SOURCE: ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Posted on Aug 17, 2008
mattballew
  • 89 Answers
SOURCE: Caller ID not working - HTC (Verizon) XV6800
Unusual problem. Check the settings to make sure theirs not a way to disable Caller ID. Give Verizon a call and see if they can find out whats going on.
Posted on Nov 25, 2008
SOURCE: XV6800 is contstantly restarting over and over
Good Day,
I expect you have tried removing the battery, re-installing and starting up again. If that didn't work, contact Audiovox technical support - they can walk you through a "Hard reset". Be aware - you must use a sync system to save your contacts, calendar, etc. It will be wiped out with the hard reset. My phone did much the same thing and the reset solved it. Afterwards, I was able to retrieve my data from the sync (I used Microsoft Activsync- downloaded free from their website).
Hope this helps.
Posted on Feb 18, 2009
SOURCE: No ring on incoming call
i had the same problem and went searching on line till i found the answer, press the # button it takes the mute off or puts it on.
regards patty
Posted on Mar 04, 2009
My iPhone incoming calls ring but do not vibrate, but all other notifications vibrate correctly.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely.
Don't worry about a reset or hard reboot. You won't lose any data or settings.
Aug 06, 2012 | Apple iPhone 3GS Black (16 GB)
My htc hd2 wont ring or vibrate even after i have did a factory reset
go to settings, then press the menu button so you go to all settings, tap sounds and notifications, then along the bottom tap notifications, then from the event drop down list select "phone: incoming call" and then on the ring type drop down list select "vibrate and ring"
that should do it ;.)
Oct 12, 2010 | HTC HD2 Smartphone
I want to replace the front face plate on the verizon XV6800 PPC
Here is a video tutorial for the Sprint Mogul, which is much like the xv6800.
http://www.youtube.com/watch?v=1lHXgVBd3j8&feature=related
Seems pretty complicated, but once you dive in its not so hard. Some people on ebay sell the faceplates and even include the tools to change it. Beware though that the Sprint and Alltel versions will not fit your xv6800. I am still trying to get one to work on my xv6800 with no success. I advise sticking to verizon's blue housing and leaving out the headaches I have had. Good Luck!
Jan 05, 2010 | Verizon Communications HTC XV6800 Cell...
My BB pearl 8100 doesn't ring for incoming calls/messages/emails, but if i go to listen my ringtones or music they all sound fine, i think it got corrupted or something because no matter how i change the...
Not sure if the pearl interface is the same as mine, a Storm - I have an option on my main screen to fast-select ring volume (called Notification), which affects both calls and messages, and I can choose loud, soft, vibrate, silent, and also go into options for more detailed settings. You may have such an option that is easy to find, and maybe easy to set by mistake, without realising it.
Pearl manual at this location:
http://docs.blackberry.com/en/smartphone_users/deliverables/1217/userguide_bb8100_gprs.pdf
see p193, Notification Profiles.
There are other keys, eg # that affect notification sounds/vibrate. Download and search in the manual for 'Notification" to find all the places mentioned.
Even if you have a paper manual, I recommend keeping the electronic one since you can easily search for keywords and find all the places they are mentioned quickly.
Sep 11, 2009 | RIM BlackBerry Pearl 8100
HTC Touch doesnt ring on incoming call
Hi. First thing, you can check your sound settings, by tapping Star Menu, then Settings, then Sounds & Notifications, and through that page, you can check if your incoming call alert is on (just sound, or vibrate and sound), you can try to change the ringtone to see if your current ringtone is damaged or not. (Since other sounds are alright, there shouldn't be any problem in your hardware or in the sound volume levels) Hope this helps.
Jun 14, 2009 | HTC Touch P3452 Smartphone
Outgoing text vibration
Good Day,
Beginning with the start menu, go to settings, then sounds & notifications. From the drop down list, go to outgoing message and click the "play sound" box (to empty). That should stop the ringing and vibration.
Hope this helps
Jan 02, 2009 | Verizon Communications HTC XV6800 Cell...
Nov 25, 2008 | Verizon Communications HTC XV6800 Cell...
Sound error when receive phone calls
first of all uninstall any programme,which you installed,or "CLEAR STORAGE" option use given in programme menu.after then set call notification only to RING.
Jan 13, 2008 | O2 Xda Atom Exec Smartphone
INCOMING CALLS
upgrade the phone to WM6 with A3.5 @ ppcgeeks.com --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
Aug 02, 2007 | Audiovox PPC 6700
Verizon Communications HTC XV6800 Cell Phone - Blue Logo
160 people viewed this question
Top Verizon Communications Cell Phones Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a Verizon Communications Cell Phone Expert? Answer questions, earn points and help others
