Question about HP Pavilion a1710n (RK573AA#ABA) PC Desktop
Cpu fan mount
The mount on my motherboard for me cpu fan is broken where do i get one at??????
  • 37 Answers
Goto: www.geekscomputer.com
or Ebay and search your motherboard model #. Boards are pretty cheap, but difficult to find those specific parts sometimes.
Good Luck,
Mark
Posted on Dec 30, 2008
Which way does the rear fan go in a compaq computer tower
The proper installation of a CPU fan is often the subject of debate. Though there are conflicting theories as to which direction the CPU fan should face, there are methods to ascertain which CPU fan installation best suits your needs. The determining factors of your CPU fan installation direction include the manufacturer specifications, your case design and the specific design of your heat sink
Horizontal Installation
  • The installation of a CPU fan horizontally to the plane of the motherboard is the most common installation orientation there is. Your options when installing your CPU fan are to blow cool air onto the heat sink or to pull cool air through the heat sink from the motherboard. Horizontal installations show negligible advantages in either installation direction. The differences in temperature usually vary by only 1 or 2 degrees Celsius. The main point to consider when installing a horizontal CPU fan is the location of the rear exhaust fan on the case. If the rear exhaust fan on the case is parallel to the processor, it is advantageous to have the fan pull cool air from the motherboard and push it out above the heat sink. This is because the case fan will quickly draw that hot air away from the CPU and out of the case, allowing for quick cooling.
Vertical Installation
  • Vertical, or tower, heat sinks rise high enough off the motherboard to allow for a fan to be installed perpendicular to the plane of the motherboard. This allows for cooling to go from the front to the back of the case, as opposed to going from the bottom to the top. Optimal installations for vertical heat sinks are blowing toward either the back or the top of the case. If there is no exhaust fan in the top face of your computer's case, it is more effective to orient your fan on your vertical heat sink so that it blows toward the rear exhaust fan of the case. If there is an exhaust fan on the top face of your computer case, it is almost always more effective to mount your CPU fan so that it blows air up toward the top of your case. The reasoning behind this is that hot air rises and will more naturally flow off the top of your case. Also, top-mounted fans are usually larger and allow for faster airflow out of the case.
Manufacturer Recommendations
  • It is often the case with nonstock heat sinks that the manufacturer has designed the heat sink's fan to be mounted in a limited number of orientations. This is usually evidenced by limited mounting notches on the heat sink itself. Most aftermarket heat sinks use technologies such as heat pipes that have specific cooling needs to operate appropriately. Because of this, it is important that in any CPU fan installation you follow the manufacturer's installation instructions.
Performance chips of BMW
May 31, 2012 | Compaq Hp - 375376-001 - Dc7600 Tower...
My pc fans runs constantly and the computer is hot
There are several things to look for here.
  • The CPU Heat sink (the big metal block with a fan) may not be making good contact with the CPU surface area.
  • Thermal compound may have not been applied between the CPU surface area and heat sink
  • The heat sink and fan are not sufficient enough to cool your CPU
  • Dust buildup is not allowing proper circulation of cooling air
If this system is not a name brand and covered by warranty then I would remove the heat sink (carefully) and verify that the mounting bracket is not broken or loose. I would check that ample thermal compound is applied, and if not use rubbing alcohol to remove all compound from the heat sink and CPU and purchase a tube of compound to apply yourself. I would also thoroughly clean the heat sink with compressed air.
If the heat issue continues then you will want to consider upgrading to a more powerful cooling solution.
The CPU fan should run constantly but in some systems will run between 50% and 100% speeds assuming a variable temperature control is applied to the system via motherboard or third party installation.
Sep 06, 2011 | Computers & Internet
I have an old computer with L4SMG/651+ motherboard. Power supply is good(checked w/a checker), but the fan works slow. Fan mount for the CPU is broken on one clip, the heat sink sits flat, but the fan sits...
That mount, sits the entire HEAT SiNK for ur processor, if it is broken the heat sink will not flatly sits on ur procie and helps out the HEAT it produces!
If u have another desktop, just try to pull out the old Hard disk and make it ur slave for ur NEW desktop, to get the data and files u wanted from that old one!
Dec 02, 2010 | EliteGroup L4S5MG/651+ Motherboard
I need a CPU mount for a SoYO P45 Dragon motherboard
check for any store in your local area that sells refurbished computer parts there you can buy a clamp that will suite you mother board
Nov 21, 2009 | Computers & Internet
Asus motherboard a8v-vm jumper setting motherbord on but cpu fan not ON
You do not use a jumper to run the CPU fan. There will be a small 3 or 4 pin plug near the CPU mount and you can plug the wire from the fan into that plug only. If the one on the motherboard has 3 pins and your plug has 4, you can use it anyway; just be sure the slot on the back of the plug matches the side of the one on the board.
Oct 28, 2009 | ASUS A8V-VM Motherboard
Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
May 21, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Heatsink/fan mounting problem
I have never heard of using a certain cpu cooler that would void a warranty.if the cooler is for the cpu then use that 1 i/e the arctic
Oct 04, 2007 | AMD Motherboard, nForce4 SLI, S939, Athlon...
Intel original motherboard d845gvsr dead
it will be cheaper and more quickly solved if you just replace it go to computergeeks.com very goo site k
Sep 22, 2007 | Intel Motherboard
HP Pavilion a1710n (RK573AA#ABA) PC Desktop Logo
108 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
