Question about Uniden PRO510XL 40-Channels Base CB Radio
Uniden Pro 510xl can send but not receive
A friend and I each have a Uniden pro 510xl CB radio in our trucks. His radio will transmit (I can hear his messages) but will not receive (he can not hear my messages). We tested both radios with others in the RV park and confirmed that it is HIS radio which has the problem.
I switched microphones in case switching in the microphone was permanently turning off the incoming amplifier, but no change. There is a hiss from the speaker, and touching a voltmeter to connections around the amplifier and speaker does produce clicks.
It's as if the incoming signal never makes it to the audio amplifier.
We looked for obvious cold solder joints, no luck.
Any suggestions please?
Ed
  • 8 more comments
  • whitetmp Dec 31, 2008
    Thanks tparsenault. Although I haven't tried an external speaker there is no doubt that the speaker is functional - we can get it to click, and it will play music when I feed it from a CD player. We already checked the solder joints around the pcb which feeds the microphone, but I'll check it again based on your comment that it's a common problem. Any other ideas would be appreciated.
    Ed
    Thank you Tom. Dumb old me, I never thought to look at the receive signal. I'll check that tomorrow.
    Unfortunately, we're in Mexico for the winter, and in a remote area, so access to a signal generator is not an option.
    Are you able to describe where the audio pin is ?
    Thanks
    Ed
    Tom, we have eliminated the antenna as a problem by switching the radios and antennas. I didn't mention earlier that we have a third friend here with the same radio and antenna so we've tested the antenna and microphone on his radio. We're certain that the problem is somewhere in the radio itself.
    Thanks for the info re the location of the audio pin. I'll try your suggestions tomorrow and will let you know.
    Thanks again.
    Ed
  • Anonymous Jan 01, 2009
    Hi Tom
    Tried your suggestions this morning with the following results:
    1.
    When transmitting, the transmit signal shows on the LEDs on the front, but when receiving there are no indications that a signal is being received. No LEDs light up.
    2.
    I placed my finger across the contacts of the 3 chips on the board, one at a time:
    IC 302 is a small rectangular chip on the main board, positioned on its side, right behind the pcb which feeds the microphone
    IC301 is a flat rectangular chip in a normal “flat-on-the-board” position almost halfway back on the board
    IC1 is the audio amplifier attached the the metal housing
    I do not have access to a circuit diagram so I have no information on what IC302 and IC301 actually do.
    3.
    I checked again the solder connections on the pcb feeding the microphone and all seem to be intact.
    Does this additional information help identify the source of the problem??
    Thank you and Happy New Year, from Lo de Marcos, Mexico
    Ed
    Jan 1/09
    Hi Tom
    1.
    2.
    3.
    Ed
  • whitetmp Jan 01, 2009
    Jan 1/09
    Hi Tom
    I tried your suggestions this morning, with the following results:
    1.
    2.
    3.
    Ed
    Jan 1/09
    Hi Tom
    1.
    2.
    3.
    Ed
    Hi Tom
    In answer to your question, even when Don is parked right next to me there is no receive signal showing on his radio.
    We had more or less reached the conclusion that the radio was a throwaway, but being in Mexico for the winter we had hoped to find a solution so that Don would have the radio working on the way back to the USA in March.
    Thanks for trying so hard to solve his problem. I'll let him know your recommendations re a replacement.
    Ed
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    The only other thing I would ask is do you notice any recieve signal on the front? My be the rf gain or squelch crapped out. If you know where the audio pin is try holding a finger across the solder conections with the radio powered up and on if you get a squeal then we know the audio circut and speaker is working, might need to put a signal gen on it and trace the rx if all else fails;
    Good Luck,
    Tom
  • Tom Arsenault
    Have you tried an external speaker? Checked around the mic connector at pcb? I have found this quite a bit on the 510 xl's.
  • 170 Answers
If you look on the solder side of board you shoud see a straight line of 5-7 solder joints, look on the other side the audio vhjp is a bmack thin retangular ic chip. Not to worry you wont hurt anything by doing this. Its an old cb tech trick to test audio chips.GOOD LUCK.
Oh one other thing does the radio have same same problem in either vehicle? A insulating washer on the antenna bracket can cause this also,
Happy New Year , Tom
Posted on Dec 31, 2008
  • Tom Arsenault
    Tom Arsenault Jan 01, 2009
    IC 1 is the one to check but I don't think that's the problem. sounds like a detector circuit or one of the rx stages isn't working. I am not one to blow smoke up you know where, To properly troubleshoot this you need to have it on a bench, Even if your neighbor pulls right up next to you and keys up do you notice receive? I think its def a rx prob and probably will cost more to fix then replace. Back in the day we got 40 bucks for the 510 xl, Get a nice cobra 25 , 29 ltd or the uniden clone. Very dependable, inexpensive radios. Really popular with truck drivers, so most cb shops have experience and parts available.
    Sorry I couldn't help out more, please look me up next time you have a problem.
    Happy New Year,
    Tom (The tech formally known as double-t in the south east coast.)
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Pro510xl schematic
do a search for it. uniden pro 510XL schematic. I found it.
Oct 23, 2013 | Uniden PRO510XL 40-Channels Base CB Radio
How to turn up modulation on uniden PRO 510xl? I noticed it has tuneable vr4, I used vr4 to turn up the modulation on my cobra 29 ltd bt but are they the same on all cb radios?
No they are different. the pro 510 doesn't have a variable like the 29.
just trace the audio wire back to the audio transformer there should be a transistor on that section. best is to change the value of the resistors controling it to increase modulation.. if you take it out.. it will be wide open.. and can cause issues like splattering on adjacent channels. same goes for cutting the audio limiting diode, will cause the same issues. leave the parts in the circuits just change the values to achieve 100% modulation on a scope or wattmeter with a modulation function.
Oct 18, 2013 | Uniden Bearcat Pro PC68XL CB Radio
On my uniden pro 510e I can transmit but I cant receive all I get back is static got any clues?
Which radio are you referring to, the Pro 510e or the Pro 510xl?
In any event, to transmit and receive clearly depends on your antenna, it's location and it's surroundings and HEIGHT.
Radio waves on these radios depend mainly on line of sight and propagation factors, If you have an indoor antenna, that could be the problem, if it's an outdoor fixture, it needs to be in such a position so that the coax cable isn't being interfered with by another electrical fixture, the Height of the antenna, is most important, the higher, the better, taking in all these factors and a bit of try this and see approach should find a solution to your reception/transmition issues. That's part of the fun of setting up a base radio, experimentation, configuration and the results you want will be worth the effort.
I hope this has been helpful for you.
Cheers, Peter
Jan 29, 2012 | Uniden PRO510XL 40-Channels Base CB Radio
I looking for sxematic diagram uniden pro 510xl
I hope you find the schematic diagram for your radio......
Aug 25, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
I have a Uniden Pro 510xl, it's about 9 yrs old. I went to use it last week and after turning it on, found that there was no sound, (turned the squelch up) . When I keyed the mic, I saw that I was...
chk mic, lose cable in **** plug test with other mic .. also test with Ext speaker.. do u get any reading on meter / LED display during RX? does PA work? otherwise your sound chip is dead
Dec 30, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I just have Uniden Por510XL (used) but don't know how to set the channel (programming) so it can match with my handheld radio (i use motorola GP2000)
well a GP2000 has a Frequency range of 136 - 174 MHz, 403-440 MHz or 435-480mhz
a uniden pro 510XL is a 27 mhz radio as far as i know...
Dec 09, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
My uniden pro510xl when hooking it up imediately blows the fuse like a dead short but if i hook up another radio it will work fine
The radio was probably wired backwards at some point. There is a reverse polarity diode inside that must be replaced to fix this. If you have continued replacing fuses and plugging it back in, there may be further damage such as finals or audio amplifier chip as well. you will need to take the radio to a qualified repairman for service. If it is simply the reverse polarity diode, your bill should not be more than an hour's labor charge.
Feb 06, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
Modification of frequency output of uniden pro 510xl
deweyp, hi, if you are wanting to turn the power up some on the radio, do this; tune L4, L5, L6, L9 for
maximum RF forward output. There are 2 versions of the radio, and both are listed as 510xl. If you are wanting to expand the freq's or add channels, then no, there is no mod for that radio. If your going to tune the radio for more power, make sure you have a power meter to watch the output. It is preferable to tune into a dummy load so your not broadcasting over the air. You tune the radio for peak output, using a steady awwww sound in to the mic. Just be careful as that radio has a fairly small driver and final transistor. Don't want to let the factory smoke out of it,,,
Here is what the little variable adjustments are for and what they control;
VR1 Squelch
VR2 TX Meter
VR3 RX Meter
VR4 RX IF Gain
Hope this helps you out, let us know,, Mechanic
Feb 19, 2008 | Uniden PRO510XL 40-Channels Base CB Radio
Uniden PRO510XL 40-Channels Base CB Radio Logo
1,094 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
