Brother IntelliFax-2820 Plain Paper Laser Fax
Problem for Brother IntelliFax-2820 Plain Paper Laser Fax
Double print or a shadow print
By davekuhar on May 02, 2007
I have an BROTHER INTELLIFAX 2820 and I get what looks like a shadow (double) print). I've changed the toner cartridge and I get the same problem. I've cleaned everything very well. I found that when I used a new drum (where the toner cartridge goes into) it works fine! My question is--- How can I fix the drum so that stops? Also, what can i use to clean it safely? thanks,
Dave
Best Solution
posted on May 20, 2007
Very Helpful)
Jimpom
Rank: Master
Rating: 83%, 76 votes
You have probably been using non genuine toner, some kinds of this toner is not the same quality as Brother toner and just chews you drum out before its due to be changed. Change the drum and use genuine toner.
Was this helpful?
Yes
No
Solution #2
posted on May 02, 2007
Very Helpful)
Chicau
Rank: Wiz
Rating: 85%, 188 votes
Unfortunately your drum unit is shot. The mechanism that cleans excess toner from the drum surface is worn out or has developed a problem. The materials needed to repair are generally not available. If this is happening then the surface of the drum is probably near the end of its usable life anyway. Save yourself a lot of grief and aggravation. Bite the bullet and buy a new drum unit. Office Depot, Staples, etc. usually offer them at about $105.
Was this helpful?
Yes
No
Popular Solutions for Brother IntelliFax-2820 Plain
Questions and Unsolved Problems for Brother IntelliFax-2820 Plain
Do you recommend Brother IntelliFax-2820 Plain Paper Laser Fax?
Answer
Answer
can you tell me how to change the time on the fax
Answer
how can you forward faxes coming in to another fax line?
Answer
brother intellifax 1250 will not copy or start to send - the copy stop and start buttons are dead
Answer
I need to delete the memory in a MFC-8500 fax machine so it can be trashed
Describe your Fax Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Fax Machine Experts
Top Copier & Fax Repairmen
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
