Question about Ovens
Faulty electric oven (Ignis AKL828/AV)
Hi there.
I have an Ignis AKL828/AV (same as Whirpool) oven which just so happened to decide it wasn't going to work on Christmas Day.I have suspected for some time that the thermostat was faulty as there didn't seem to be a low heat setting.On the day in question I turned on the oven (used previously in the day) and left it to heat up.After a while an MCB tripped and when turned back on, the oven wouldn't heat up.It is a single fan oven with built in grill, which still works.
Many thanks for any help given.
David
  • davedee_1 Dec 31, 2008
    Hi barkencoa.
    Thanks for the info but what I'm now wondering is if there is any other reason the oven would stop heating i.e. faulty temp control and /or thermostat .I don't want to replace the element just in case it's something else.I've had the element out and it "appears" ok.
    Many thanks.
    David
    Hi again!
    I decided to bite the bullet and bought a new element today which has been fitted and is working.It wasn't expensive.It was only £24, which considering the price of a new oven is quite acceptable!
    Thanks for your help and all the very best to you and your family for 2009.
    David
  • Ovens Master
  • 3,463 Answers
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
Posted on Dec 30, 2008
  • Barry Coates
    Barry Coates Dec 31, 2008
    Hi .
    I appreciate your concern, but the fact that the element looks o/k , proves nothing.
    You need to test it, to be certain,there are two ways of doing this, if you have a meter, set it on the ohms range to test for continuity, and put the probes onto the heater terminals, the needle should swing all the way over, if it does not , then the element is no good.
    The other way is to test the element in situ, with the element disconnected from the oven but with the wires still connected, test for voltage , if you have a supply but it is not getting hot, then again the element is faulty..Only do it this way if you know what you are doing,
    Remember electricity is s silent killer!!!!
    Good luck.
    I still do not think it is the stat that is faulty.
Instructions for a ignis electric oven as there is no temperature guide or modes on front of oven
I don't see what looks like your model anywhere, or a manual for any model, or a company website, so if no one can help you try this.
The left dial could be- bake, broil, fan, convection cook, now the bottom pan should come out so you can see the bake element.
Turn it one setting and see what happens, either broil (top),,, bake (bottom), convection fan (bottom), turn and wait to see what happens.
Right should be temp, not sure if the dial has a stop or you can spin, but it at 12:00, put at 6:00 I say this maybe 300deg F.
Get over temp gauge (cheap).
If you don't get any help, then you need to try and see what does what and mark it down.
If you can't see top burn, maybe top pan come out so you can see it.
They get red hot, so you can tell which one turn on.
Sorry, can't find any info.
Apr 01, 2013 | Ovens
Ignis AKL828 door hinges locked in shut position... door off oven!
Take a pair of pliers and pull the hinge out of the socket. This will take care of it. After doing this, then simply set te door back in place and shut.
Mar 06, 2013 | Ovens
I had an ignis build in, single, fan oven, model AKL907/IX installed in January, worked fine now, switches off when the oven is on, beeps and then can be restarted if pressing the ok button, however the...
Hi i have the same oven, Ignis AKL907/IX. Worked ok for 12 months but now cuts the power in the whole house out when the cooling fan is engaged. Just out of warranty and call out fee is
Aug 15, 2010 | Ovens
Built in oven front panel gets too hot
No. There should be a fan that runs and blows cool air from a gap at the top of the door and over the controls.
Feb 15, 2010 | Ovens
Help!!!!!!!!
Sounds like the oven element is faulty.
This is usually located at the rear of the oven compartment behind a remov eable cover.
Please rate my solution.
Thankyou
Jan 25, 2010 | Ovens
Oven not working, is it the thermostat or element
This will almost certainly be the element and is fairly simple to replace.
Nov 28, 2009 | Ovens
I have whirpool oven GBS 307PRS00 after selfcleaning won't heat back up is this the fuse and can i replace it myself?
It was the TOD a little sensor in the back of the oven, it happened because when you self clean the temperature goes up to 1000 degrees. never self clean over 2 hours and only do it as
little as possible.
Oct 30, 2009 | Whirlpool GBS307PRS Stainless Steel...
AKL 888/01 ELECTRIC OVEN IGNIS STARTS FOR ABOUT A MINUTE THEN STO
hi did you every get this problem resolved as i am now having the same issue?
Thanks Mikala x
Mar 31, 2009 | Ovens
Fan works but oven doesnt get hot
One of the switches looks to be a 5 position switch. 0=off, 1=Light, 2=fan
Feb 24, 2009 | Ovens
Ovens Logo
1,214 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
