Question about Brother MFC-8860DN Printer
Machine error. no error code.
My printer keeps giving me a message that says Machine Error. Turn machine off and call Brother. There is no Machine Error code. Any way to fix this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Posted on Jan 15, 2009
  • fode diakhate
    fode diakhate Dec 30, 2014
    machine error 9B plz help
    New Friend:
I see in the LCD Machine error 9B plz tell me what i do to fix it
Posted on Dec 30, 2014
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
My brother mfc 495cw keeps giving an "unable to init." error message. chris.iya@lausd.net
Hi. my machine model MFC 495 CW. I did any step but my machine till show up unable to Init. 4 F. please can you help me about that. thanks you very much
Tien
Sep 07, 2010 | Brother MultiFunction Center MFC-440CN...
I have a Brother MFC 9440 CN All in one printer and it says unable to print routine maitenance help!
this message normally indicates a physical problem somewhere on the machine, try turning it off for a couple of minutes then back on. if it keeps giving you this message it should at least give you the error number as well
Mar 24, 2010 | Brother MFC-9420CN All-In-One Laser...
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Jan 26, 2010 | Brother MFC-8440 All-In-One Laser Printer
Machine Error 8460N Laser Printer
To get the machine error code
Get into maint mode
Within 2 seconds hit:
menu,*,2,8,6,4
This will put you in maint mode.
Press 82
This will give you the machine error code.
Press stop/exit
press 99 to exit maint mode.
Let us know what the machine error is.
Jan 16, 2009 | Brother MFC-8460N Laser Printer
Press 99 to exit Maint mode.
Dec 30, 2008 | Brother MFC-8860DN Printer
Mfc9880 machine error 71
error 71 is a problem with the polygon motor which is in the laser unit. This error usually means that you would need the laser unit replaced.
I'd suggest calling out an engineer.
Dec 12, 2008 | Brother MFC 9880 All-In-One Laser Printer
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother MFC-8860DN Printer Logo
1,221 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
