Fuse blows on crate fxt65 amp
I got an amp from my Nephew but the fuse continues to blow every time it is turned on. I look on the circuit board for anything obviously touching...nothing
Any Ideas
Mike
  • jakes5505 Jan 03, 2009
    model crate FXT65 serial No (21) 07GBPB0128
    Mike
  • rah1379 May 11, 2010
    can you tell me the model number on the back? is this a tube type amp or transistor? i can help you but some guitar amps have lethal voltages inside and we have to be sure what we have before i can tell you what to check and how to check it.
    Genius:
  • 1,175 Answers
Hi...
It's a transistor type design. Most likely the power transistors or power amp module that drives the speakers.
If I were the repair shop I'd charge about $80.00 to fix it
Posted on Jan 02, 2009
I have a 03 isuzu rodeo and every time I turn the ignition the turning signal fuse blows
Most likely a short in the directional circuit. Start at the blubs and disconnect the connectors at the bulb sockets. disconnect one at a time and see if the fuse continues to blow. When the fuse stops blowing you have found which circuit it is. Also, this could be the stalk switch on the steering column. disconnect and see if the fuse blows, and don't forget the 4 way flasher switch also. Lastly, pull the relay and check if the fuse still blows.
Sep 29, 2015 | Isuzu Cars & Trucks
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Gx 15
Amps have fuses inside. Check them if they are blown. After replacing, if it keeps blowing, then you have a short that needs to be fixed. Good luck!
Mar 27, 2014 | Crate Music
Fuse blow each time I turn on air check for
disconnect the thernostat wires from the control board. Put a jumper wire between R & G put door back on and turn on power. Blower motor
should run, if it blows the fuse then you have a direct short between R &
G at the board. Do this with R and W(heat) and R & Y(cool).
By disconnecting the thermostat wires and reinserting them make sure that they do not touch when inserted into each terminal. If it still blows
that little 3amp fuse when jumpering between each sequence as mentioned above, then I think your board is bad. When Jumpering out the Y terminal you will have to have the AC wires still hooked up. If it
blows the fuse in that sequence. Disconnect the wires out at the condensor.
You mat have a bad contactor at the outdoor unit.
Jul 16, 2010 | Goodman GMS90703BXA Heater
The circuit board has a 25 Amp slow blow fuse is blown
if your circuit board has a 25 amp fuse that a lot of power, like running the compressor.. you need to have a model and serial number for the unit , there is no generic control board , each manufacture has it's own design
Nov 15, 2009 | Refrigerators
My compressor stoppped running. i found a burned out fuse inside. i've replaced the fuse. the fuse was labeled 3a250v. thats what i replced it with. when i turn it on the fuse blows immediately. on some...
Every time I connect my Campbell & Hausfeld fp200300av Compressor and push the power on, the fuse blows. Even if I disconnect the motor from the circuit board the fuse continues to blow. Then I extracted the Rectifier-diode (the black and square with a hole electronic with four stands part).
This piece was the reason of the short circuit, I replace it with an equivalent one and I accomodate it to the right terminals in the circuit board. My compressor works flawlessly again!
Sep 24, 2009 | Campbell Hausfeld Air Tools & Compressors
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
I have a Toshiba 61H71 that keeps blowing F850. It was just sitting there the first time it did it. I didn't have a replacement fuse so I temporarly replaced it with a 3A glass barrel type fuse. This...
Resolder jumpers on signal PCB..May be near convergence IC circuit..on 50" model they are 050 & 010. You may have solder cracks..I repaired a 50" toshiba..Let me know if this fixes
Apr 15, 2009 | Toshiba 61H71 61" Rear Projection...
DeWalk DC500 wet/dry vaccum doesn't work
Vacuum works with the battery but does not work with 120 volt. Every time I plug it in it blows the internal fuse. I have replaced the fuse inside the vaccum several times and every time i plug it in it blows. What do you think it could be?
Feb 21, 2009 | Dewalt DC500 Canister Wet/Dry Vacuum
270 people viewed this question
 Grubhead
Grubhead
