Question about GPX MW-3847 MP3 Player
IS GPXMW3847 COMPATIBLE WITH WINDOWS VISTA?
I CAN'T GET THIS DEVICE TO WORK. I THINK I HAVE FOLLOWED ALL INSTRUCTIONS, BUT I KEEP GETTING A MESSAGE THAT SAYS IT CANNOT SYNCRONIZE.
  • CHARL1SA Jan 09, 2009
    I AM READY TO TAKE THIS MESS BACK!
L had the same problem. I had a problem song that I had to remove. Then I had to reboot the GPX back into the computer. It took me a couple of tries but I finally figured it out. When you first plug in your GPX it asks you if you want it to sync automatically I picked not to and it seems to work. I hope this helps you.
Posted on Jan 08, 2009
I get an error message %d dpi when I try to print (I just installed the Service Pack 1 for Windows &). How do I solve this?
Hello nvpenter,
I don't think Oki makes a driver for Windows 7. I would try installing the drivers in Vista compatibility mode and see if that works. I've put two methods below that may help you resolve your issue.
Method 1: Run the Printer troubleshooter and check if it helps.
Method 2: Uninstall the existing printer drivers and install the Vista drivers in the compatibility mode.
a. Right click on the setup file (setup.exe for the drivers) and select Properties.
b. Now click on the Compatibility tab and check the box which says "Run this program in compatibility mode for."
c. Select Windows Vista (Service Pack 2). Click Apply and OK.
d. Now right click the setup file and select Run as Administrator and follow the normal installation procedure. Check to see if you can use the printer now.
Feb 28, 2011 | OKI C5100n Laser Printer
Navman n40i smart st compatability problem with vista.
Are you not able to run the activesync program despite the Vista warning? Did you try running it in compatibility mode? What happnes when you try to connect with sync center (what happens...any error messages)? Regarding the mobile device centre...did you check that McAffe and windows firewall is not blocking it from internet access?
Jan 26, 2008 | Navman NavPix N40i GPS Receiver
I am trying to load my daughters digital arts and craft studio to windows 7 and it keeps prompting that it can't pick up the device. How do i install it to windows 7 because it was working perfectly with...
1.your software may not be compatible with the Windows 7 and will have to be run in the compatibility mode for Windows Vista.
Check the compatibility mode for the Vista to install your "craft studio"cd it may not be compatible with Vista and can only run in XP mode or Windows 98.
here is the instruction from Microsoft to use the compatibility mode in Windows Vista:
http://windows.microsoft.com/en-us/windows-vista/make-older-programs-run-in-this-version-of-windows
Aug 10, 2010 | Computers & Internet
Lexmark x2480 will not install in vista
It's possible you have a corrupted setup file
Will any other USB devices install on your machine?
Error message when you try to install a new hardware device in Windows
Vista: "Windows encountered a problem installing the driver software for
your device"
Refer :)
http://support.microsoft.com/kb/937187
Thanks.
Dec 05, 2008 | Lexmark Office Equipment & Supplies
Vista install
insert the vista disk and shut down the computer
restart the computer and hit the f10 key repeditivly this will bring you into bios, choose boot order and choose to boot from cd rom
follow the instructions from there.
May 11, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Window vista
Please provide the error message, the notebook make and model, and please classify " will not work right" the error message code will take us a longway - from face value it seems that your notebook is not compatible in terms of hardware specs with Vista.
Regards
Hands of Time
Apr 27, 2008 | Microsoft Windows Vista Ultimate Edition
Lexmark z11 Vista Compatible?
Looks like I've cracked it [Touches wooden desk]. Need a USB to IEEE 1284 36-pin Parallel Printer Cable, like the one I received today (ordered yesterday from www.cables2u.co.uk). First, connect it to Z11. Turn on Z11 and boot up Vista PC/laptop. (I run Vista Business on my laptop.) Connect cable to computer. Message appears "Installing device driver software". Click it for status. 'Found New Hardware' box appears. Click 'Locate and install driver software'. A message appears "Error loading LXADSUI.DLL. Specified module could not be found". Click 'OK'. Message appears saying driver software installed successfully. ["Yeah, right ..."] (Have faith, folks!) Now, click Start, then Control Panel and double-click Printers. Right click on Z11 and click on Set As Default Printer. Right click on Z11 again and click on Properties. Check on Ports tab that Port USB is ticked for Z11. On Cartridge Maintenance tab, check right cartridge is showing. If not, click 'Install/Change Cartridge' and follow instructions. Then 'Clean Print Nozzles' and 'Align Cartridges'. Check settings on the other tabs in Properties look OK and try printing a test page! It looks good to me!
Jan 15, 2008 | Lexmark JetPrinter Z11 InkJet Color...
Lexmark X5070m for Windows vista
I have Windows Vista Home Premium and I am thinking about getting one of the X5070m printers. I talked to my computer repair tech first to get his opinion and he told me to load the program disc first and follow the step by step instructions and NOT to connect the printer until it tells you to. So yes, uninstall and reinstall the program and follow the above and you should be set. If not...let me know before I buy one too.
Dec 20, 2007 | Office Equipment & Supplies
CanoscanD1250U2
I am fairly sure this is Vistas UAC, coming into play, I think you need to Elevate the Permissions to Administrator for it to Install and work. here is an explanation below. Sometime you must "Install" the software in "Compatibility Mode" also. technet2.microsoft.com/WindowsVista/en/library/00d04415-2b2f-422c-b70e-b18ff918c2811033.mspx You have to be an "Administrator" to do certain things in Vista and the User Account Control has to be setup correctly to work.
Aug 17, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
GPX MW-3847 MP3 Player Logo
61 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
