Question about Brother MFC-8860DN Printer
Machine error. no error code.
My printer keeps saying Machine Error. Turn machine off and call Brother.
  • cyberrtb Feb 03, 2009
    i also have the same problem. with my mfc8860dn. i went into service mode and the machine showed machine error 55. please help.tanx
  • Teis Thomsen
    Teis Thomsen May 11, 2010
    That migt just bee a great idea :-)
    /Teis
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Go into maint. mode.
With-in 2 seconds hit Menu,*,2,8,6,4
Then hit 82 when in maint mode.
This will give you a machine error code.
Let me know what that number is and I will help you with a solution.
Press 99 to exit Maint mode.
Posted on Jan 15, 2009
  • 1 more comment
  • Daniel Sanchez
    Daniel Sanchez Mar 27, 2014
    IN MY CASE USING THIS STEPS I FOUND A 6A CODE. THIS COULD BE TO THINGS: THE THERMISTOR OR LAMP FROM THE FUSEER .
  • John Tuminaro
    John Tuminaro Mar 27, 2014
    Fuser replacement is the best repair for this issue....
  • John Tuminaro
    Or you can check the connections for the wires coming from the fuser to the right side...
    New Friend:
    Problem Solver:
  • 5 Answers
Turn off the printer and back on press ''menu''-''start''-''088'' then it will come parts replacement on screen press down key ''fuser replacement'' press set done
Posted on Nov 29, 2013
3 Suggested Answers
  • 12 Answers
SOURCE: Brother 7020 printer "fuser error"
The fuser has failed and needs to be replaced. If it is still under warranty Brother may cover it. If not you will have to take it to a Brother Authorized service center. It may be possible to find a used one on Ebay, even if its just for parts. Some of these smaller machines require extensive dissassembly to replace the fuser and shouldn't be attempted by a novice.
Posted on Mar 27, 2008
jtuminaro
  • 56 Answers
SOURCE: machine error. no error code.
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
Jan 26, 2010 | Brother MFC-8440 All-In-One Laser Printer
When i turn on my brother mfc 8440 it is saying
For the error code "7a" to be fixed permanently, you need to ensure that the main PCB is fine and is working in good condition.
If the error code is caused due to malfunctioning of the main motor, then you need to check the whole setup by connecting it with another motor.
In this case, make sure that there is no mechanical load present on the main board.
While fixing this error code, you will notice that the motor runs slowly initially and then picks up the speed later.
http://www.fixya.com/support/t5660619-7a_error
Oct 01, 2009 | Brother MFC-8440 All-In-One Laser Printer
Machine Error 8460N Laser Printer
To get the machine error code
Get into maint mode
Within 2 seconds hit:
menu,*,2,8,6,4
This will put you in maint mode.
Press 82
This will give you the machine error code.
Press stop/exit
press 99 to exit maint mode.
Let us know what the machine error is.
Jan 16, 2009 | Brother MFC-8460N Laser Printer
Dec 30, 2008 | Brother MFC-8860DN Printer
Machine error 71
Error code 71 -- ( Polygon motor does not synchronize with the reference clock. ) What ever that means - hope that helps.
Mar 20, 2008 | Brother MFC 9700 All-In-One Laser Printer
Brother laser mcf-8440/ machin error 7a
Oct 26, 2007 | Office Equipment & Supplies
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Will not initialize
Take it back to the dealer! Better do not fix that problem by opening the printer! If it is a second hand printer, write again here.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Machine Error 41
Error code 41, Print cartridge is bad and gone out. Needs to be replaced by authorize dealer for just under $100.00 ($55.00 part & $40.00 Labor).
Nov 14, 2006 | Brother IntelliFAX 1800C All-In-One...
Brother MFC-8860DN Printer Logo
663 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
