Question about Dryers
When dryer is on it continually makes squeaking sound
It is a GE Dryer model DWSR483EBOWW form 2002
You need some lubrication inside the dryer. There are several pulleys and a belt tensioner that can be noisy if not properly lubricated. Be careful to use only an approved lubricant to avoid a possible fire hazard.
Posted on Dec 30, 2008
GE dryer Mod # DWXR463EG1WW is squealing. Does anyone know what is wrong with it and how I can fix it?
Sounds like a rear bearing . remove the 2 screws from the top when you open the door . this way you can take the top off . When you take the top off remove the screws on the inner left and right on the front panel. disconnect the belt from the pulley and motor and pull the drum out . then you will see the rear bearing . cheap fix but can be a pain. good luck
Feb 16, 2013 | Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My GE DSXH43EA2WW Dryer is making a squeaking sound when running. Tends to get less noisey as the dryer continues to run
Hello
You will need to replace the dryer belt and inspect the belt rollers while you have it apart. If you go to the web link below it explains how to take apart the dryer to replace the belt, it has additional links to pictures and diagrams within the instructions. The first link is for replacement parts with diagrams of the dryer. Here is that link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130504&diagram_id=21844825#d21844825
The next link is the Do It Yourself Article on replacing the dryer drum belt. while you have it apart remember clean the lint and dirt out of the cabinet interior. Here is the repair link:
http://www.applianceaid.com/ge-dryers.html#belt
Jan 14, 2011 | Dryers
I HAVE A GE GAS DRYER MODEL DDG5980VALWH SER. 3F302890G. WHEN THE DRUM TURNS IT MAKE A THUMPING SOUND,,NOT REAL LOUD. MORE OF A THUMP THEN A SQUEAK.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 12, 2010 | GE Dryers
Dryer makes a squeaking noise when running. I know it's coming form where the drum connects to the back of the dryer
rear bearing kit part number WE25X10001.the drum rides on the rear bearing and that's what is worn out on your dryer
Dec 12, 2009 | GE DSXH43EAWW Electric Dryer
GE dryer, model DBXR453EVOWW - squeaks at start up
It could be the rear drum bearing, or the belt needs replacement.
Aug 28, 2009 | GE DBXR453EV Dryer
The dryer has started to make a slight squeaking noise, but it is still drying
On a GE dryer the part that squeaks most is a WE3X75. Centerpost drum bearing. It is a simple repair but you must get into the machine.On a frigidaire model The plastic bearing that mounts in the rear sorta like a GE model. No other dryers that I can recall have the squeaks. The newer GE dryers are made very simular to the old reliable frigidaire models so you ought to hit it out the ball park with these 2 links.
Jul 09, 2009 | Dryers
GE profile dryer is making squeaking noise.
please replace felt around drum thank you for useing fixya RATE ME
May 17, 2009 | GE Profile Harmony DPGT750EC Electric...
Scraping/high pitched noise in GE model DCVH515GFOWW.
heatman101
sfdyjsdf
Mar 03, 2009 | GE DCVH515GF Gas Dryer
My dryer is squeaking on the dryer spin cycle.
What is your model number ...sounds like the drum glides are going out or the support rollers
Jul 31, 2008 | Dryers
Dryers Logo
354 people viewed this question
Top Dryers Experts
