Question about Acer Notebook
Password not valid?
I set a passord for bios /also had a usb 16 gb connected  now computer doesn't go with on without  a password  its the same pw  i always use to go on  please help
I need to access the BIOS of an ACER Aspire 1E 522 laptop before I buy it. The owner has forgotten the PW. The BIOS battery can't be easily accesed keyboard must be removed.
fixya does help people (2,617,864 my self alone ) but to get help require some input from yourself
you will have to take it to a computer repair shop to get the password removed and the bios and the pc will work very well without a bios password
besides the bios password you will need his administrator pass word to open the program
Oct 02, 2016 | Acer Computers & Internet
Why is admin PW locked?
BIOS passwords can add an extra layer of security for desktop and laptop computers. They are used to either prevent a user from changing the BIOS settings or to prevent the PC from booting without a password. Unfortunately, BIOS passwords can also be a liability if a user forgets their password, or changes the password to intentionally lock out the corporate IT department. Sending the unit back to the manufacturer to have the BIOS reset can be expensive and is usually not covered in the warranty. Never fear, all is not lost. There are a few known back doors and other tricks of the trade that can be used to bypass or reset the BIOS
check the link, press the helpful button
How to Bypass BIOS Passwords
Jan 23, 2016 | Dell LATITUDE Computers & Internet
How to remove password
which password, power on password or o/s password?
if its power on password you need to reset BIOS. by removing the coin cell battery on the motherboard together with a jumper just next to the coin cell. its called CMOS. Power on the computer and all the bios settings will be reset including the passsword. if its o/s passord that is created in the control panel you need to use a software called password xp.
Oct 04, 2013 | Computers & Internet
Password
To reset the Belkin back to the defaultsettings -
Press and hold the pinhole RESET button at the back of the router and thenpower for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open abrowser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter)You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 20, 2012 | Belkin Computers & Internet
Forget passord
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased. Hope this helps
May 28, 2011 | Western Digital My Book Essential Edition...
I forgot the password. so i cant log in now. wat i should do?. help me
If you lost windows password, you can go into safe mode (F8 when booting up) to recover windows password, but you forgot administrator password, that way doesn't work. you must use software to recover administrator password. This method is very easy. You can go to this site http://www.reset-windows-password.com/how-to-reset-windows-password.html
Jan 05, 2011 | ASUS Eee 4G Notebook
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
I like to set the user password in the bios for boot up protection. I enter the pw in the setup but the computer just ignores it and boots without asking
make sure have set the pw for the system and not for the bios. they arte two different things. also make sure u chose the option to save and exit after setting the pw. save and exit is usually the f10 key
Oct 17, 2009 | HP Pavilion Media Center TV m7350n...
Need to reset phoenix bios on toshiba A215-s5825. Bios password has been set by accident. Backdoor passwords do not work, and removing battery from the motherboard did not work. Please...
If there's a shorting terminal in your mobo for reset BIOS PW short it with its shorting pins then check it out again if PW is cleared from BIOS.
May 24, 2009 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
