Question about Canon imageRUNNER 1023N Black and White Copier
I have a canon image runner 1370 f
I can not put the toner casing in properly (this is the casing that the toner cartidge goes into)
    Scholar:
  • 62 Answers
Remove the toner cartdrige and then put the toner casing in... it should go down no problem.... then close the bluse cover, slide the plate to your right and open the small front cover.... there you should find and follow the position to correctly install the cartdrige... it only has one good way to be done.
Posted on Jan 24, 2009
Canon image runner ir 5070 error E00020
E0020. problem with developing unit. sometimes or often toner doesn't full of motor developer, it is may be the toner become froze or no toner.
Dec 26, 2012 | Canon Image Runner 1630 Copier Copier
Error code E-000013-0000 on a Canon Image Runner 5000
e-000013, it is all about waste toner.
possibility :
- waste toner case was detecred full.
- The PLL lock is released because waste toner motor is locked up, etc.
- The micro switch employed to detect clogging of waste toner is activated.
the position behind-below of copier.
open the beck cover and you ll see it.
the waste toner case
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
Copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Jul 25, 2010 | Canon imageRUNNER 2870 Copier
Cannon imagerunner 3320i has excess toner coming out of toner cartidge area. I can clean it and its fine for two copies, but after that... all copies start turning black.
You need a black image unit , I can give you a price on one and walk you thru replacement. My e-mail is geminibusiness@att.net
May 13, 2010 | Canon Image Runner 3320I Copier
I need to know what is the kind of drum a Imagerunner 1630 uses.
An OPC Drum is used, you can use Drum of these models image runner 1310, 1330. 1370, 1510, 1530, 1570
Mar 29, 2010 | Canon Image Runner 1630 Copier Copier
Replaced toner in a Canon image runner 2200 copy comes out blank
1) you do not dump toner into the drum! Juo dump it into the toner unit.
2) didi you after replacement put the blue toner handle (right from toner unit) into the left position?
May 27, 2009 | Canon (6981A002AA) for imagerunner 2200,...
I have a canon image runner 1370 f.
Are you trying to replace the old toner or is this the first time -- new out of box? There is a pattern / order you have to follow to replace the cart. To make it easier, have the right cover open while doing this ( replacing the carts). Also make sure that you have the protective covers and tape off of the cart. Use the light colored area on the cart. to hold and DO NOT TOUCH THE DRUM !!!
Dec 30, 2008 | Canon imageRUNNER 1023N Black and White...
Canon imageRUNNER 1023N Black and White Copier Logo
60 people viewed this question
old marine
old marine
