Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Replacement for the spring loaded door on my tower
The spring loaded door at the top of my Compaq Pasario tower is broken. This is the door that opens when the eject cd tray button is pushed. It closes when the tray retracts. The spring is held in place by two small plastic nipples. One broke and now the door will only flop open. It will not retract. Can you help me find a vendor with a replacement part?
  • sanmojc Dec 30, 2008
    Thanks for your comment Jerry. It is not the cd player that has the problem. It is the tower case that is broken.
    SR2044NX
    Problem Solver:
  • 12 Answers
No solution for this. All cd players are non repairable or at least not cost effective to repair. My advice is to just purchase another one. Cost for these is now in the $40.00 range - cheaper then getting this one fixed
Posted on Dec 30, 2008
  • Gerald Burnett Dec 30, 2008
    I will check into that for you.
    What is the computer model?
How can I repair or replace the spring on the door?
generally you open door all the way, then brace it in an open position with a couple of 2x4s on each corner or something like those to hold the door open all the way on their own. then replace each spring by lifting it out of the top metal brackets. need some lifting power to accomplish this. good luck. make sure you replace with exactly the same spring=take broken with you for new.
Mar 28, 2015 | Electrolux Dishwashers
How to repair kitchen aid door springs
proceed according and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Nov 01, 2013 | KitchenAid Microwave Ovens
I'm unable to open the microwave door on model Sanyo EM-S8586W as it appears the spring is broken. How do I remove the cover so I can replace the spring please?
make this steps and fix it. God bless you
Oct 26, 2013 | Sanyo Microwave Ovens
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How do i open the door on hotpoint WD440, latch is broken?
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.
You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Please rate my solution.
Thanks.
Nov 06, 2009 | Hotpoint Aquarius WD640 Front Load...
The hinges on the top loading door no longer keep it open when we pick it up to load the clothes. How do I check to see if the hinges are broken or if they are simply out of their sockets?
YOU MAY BE MISSING THE COMPRESSION SPRING OR IT HAS COME LOOSE.
LOOK UNDER THE DOOR AND YOU CAN SEE THE SPRING.
YOU MAY HAVE TO TAKE THE TOP OFF TO RELOAD THE SPRING.
BE CAREFUL IT BITES.
IF YOU DONT HAVE A COMPRESION SPRING YOU MAY HAVE THE WOUND STYLE YOU MAY BE ABLE TO REHOOK IT
WEAR GLOVES WHEN YOU
TRY CAUSE IT HAS SHARP ENDS.
GO TO THE LOCAL USED WASHER REPAIR AND PICKUP AT A SMALL CHARGE. iTS EASY TO REPLACE EITHER.
GOOD LUCK
Aug 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Oct 25, 2008 | Belling SGE12X Front Load Washer / Dryer
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
206 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
