Question about HP LaserJet 1100a xi All-In-One Printer
My scanner is not working
My printer is HP laserjet 1100A. Before my scanner is working but now does not work and even the copier of it. Please help me
  • 449 Answers
SOURCE: scanner busy!!
try to look on the taskbar
right click on the printer icon then
cancel all printing that are pending!!!
Posted on Nov 10, 2008
SOURCE: Scanner will not multi feed takes several sheets
compatible DVD decoder is not installed on my computer. how could i install it ???
Posted on Feb 15, 2009
  • 108 Answers
SOURCE: unable to receive fax from HP LaserJet 3050
Please make sure the machine is set for auto-receive in machine set up and make sure the phone cord is plugged into the line jack on the machine. If this machine is not on a dedicated phone line the machine (rings) should be set to pick up before the answering machine does.
Posted on Aug 28, 2009
  • 30 Answers
SOURCE: I Have a HP LaserJet 3030 Printer works
Have you loaded the drivers and set up your fax ie name number etc tone pulse. fi you have done this. then you will need to delete driver and reload.
Posted on Oct 10, 2009
  • 150 Answers
SOURCE: I installed drivers for hp 1100a printer scanner
Try to get new drivers from
Posted on Feb 14, 2010
SOURCE: Scanner Error 5 "error message" on my all in one
I had this problem and it had to do with the scan bulb head not recognising the marker. My temporary fix until the bulb is replaced is to turn the printer off, open the top (ADF and all) with the gray button on the right so that it's slightly raised and then switch the printer on. When it comes up, just close and print/scan/copy as usual. Apparently the spring in the arm warped the interior surface where the head moves and it can't line up when it's closed. Hope this helps.
Posted on Sep 01, 2010
0 characters
1 Points
Have an old computer with Windows 98 and need driver for HP Laserjet 4L
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
Feb 01, 2013 | HP LaserJet 1100a Printer
HP 1100A scanning issue
that is a double feed prevention pad or friction pad commonly known as a sep pad! the part number is RF5-2886-000CN the kit is about 35.00 let me know if ya need one..
Mar 31, 2010 | HP LaserJet 1100a Printer
Single sheet paper on my HP LJet 1100a works fine
There is a recall fix on this printer if it has specific feed problems like pulling in multiple sheets etc. Might be related. You can contact HP and they'll send you a DIY fix kit to replace the rubber that pulls the sheet in and onto the rollers.
Feb 07, 2010 | HP LaserJet 1100 Printer
Hp laser printer 1100a ,after few pages printing all the three lights of priter on, then it did not work further. results shows pending. when i off the printer from main power supply then it work. what i...
I had to jump in my 'time machine' for this one, but it is probably as simple as a low toner cartridge. remove it, and give it a shake, then replace it, to see if that solves the problem in the sort term. Get a replacement cartridge if it does.
please let me know
Apr 04, 2009 | HP LaserJet 1100a Printer
Feb 15, 2009 | HP LaserJet 1100a Printer
HP LaserJet 1100A unwanted toner marks on face of print
check this link,
either fuser or print drum. to verify , start print job, open door before finnished and see if marks appear before or after fuser. Before paper gets to fuser toner ink will smudge.
Use of scanner hp laserjet1100a
There is not a simple "how to" explanation for you, for this old printer. I wouldn't be surprised if there wasn't even a driver available for this machine at this point.
If you are a beginner, I would suggest a new printer/scanner that is much more 'user friendly' than the old models.
Feb 06, 2009 | HP LaserJet 1100a Printer
you need to download scanner software for that unit then put what you want scanned in the scanner slot & the pc should see it.
Jan 16, 2009 | HP LaserJet 1100a Printer
HP LaserJet 1100a xi All-In-One Printer Logo
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
