Question about Philips Magnavox 27MS343S 27" TV
Picture is in 3D
Phillips 50P8341. Its like something is not lined up, you can see everything twice. The best way I can describe it, is it looks 3D.
  • rdburris Jan 01, 2009
    I've tried to line up the red and blue multipoint, but for some reason it will not line up straight.
Sounds like you have a ghosting issue. that means its not tuned in properly. i also had the same problem before. it happens to certain flat screen tvs. try tuning in on a different station or channel example av or tv1 or tv2
Posted on Dec 30, 2008
Hello, I have a 60" Phillips rear projection TV
It sounds like a convergence problem; depending on your skills it may or may not be something you can do (parts cost on EBAY will be under twenty dollars).
I will attach some convergence photos: does your set look anything like these?
If it does and you can solder etc I can tell you the best place to get the parts and how to do it.
Before you rate this information let me know what you find.
SD TECH
Aug 16, 2011 | Philips 60PP9202 60" Rear Projection...
Phillips 50P8341 will stay on about 15 mins then shuts off then the power button flashes twice, pauses then flashes twice again...
Seems like it is overheating. Try cooling it down by using a fan to blow air into it (temporary fix). Make sure the TV is well ventilated and heat can escape (permanent solution).
Jan 15, 2011 | Philips 50P8341 50" Rear Projection...
Shadow effect on picture. Picture is fine but there is a red shadow tint to everything (basically everything is written twice, but not in the same spot)
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture is not clear. Has a green tint and glow.
Repalce the coolant in the CRTs. You can get the Phillips CRT coolant replacement kit at www.tvrepairworld.com the kit contains the coolant and the CD with instructions
Oct 13, 2009 | Philips 50P8341 50" Rear Projection...
I am having a hard time adjusting the color and focus on my Phillips 50p8341. Can you help?
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 12, 2009 | Philips 50P8341 50" Rear Projection...
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
www.mcveyelectronics.com
May 03, 2009 | Philips 50P8341 50" Rear Projection...
I have a phillips rear projection 51PW9303 red and green lines showing in the left corners and red line thru middle of screen, bottom of screen shadows and so does left top corner if numbers and...
sounds like youre describing a convergence problem. Do the letters look like theyre 3D? If so you will need to replace both Convergence ICs STK392-120 you can get replacements at the following link and they include installation instructions with pictures plus gree tech support. heres the link.
http://servicemanuals.vstore.ca/
Apr 24, 2008 | Televison & Video
Phillips model 50p8341 titanium-finished 50-inch Red tint to picture
Your Red CRT may be on its way out. Try turning down the G2 screen control on the red CRT just a little. That should help for now. A new red tube wil be a reality in the future.
Jan 21, 2008 | Philips 50P8341 50" Rear Projection...
Philips Projection Tv (50p8341)
take a real good look at the quality of the picture you have now b4 putting any money into this product many of the phillips projo tvs out there have burned fluid in the crts that needs to replaced also up to an including new crts the convergence amps are the black things that say stk392-110 on them two of them that would would get you customer convergence back again do you know how to solder?
Dec 07, 2006 | Philips 50P8341 50" Rear Projection...
Philips Magnavox 27MS343S 27" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
