Question about Nintendo Wii Console
My wii remote vibrates but not work.
My wii remote does not work, I have reconnected it and synced it.  It only vibrates.
  • 34 Answers
Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Feb 25, 2009
My PDP Rock Candy Wii Remote Isn't Working
Have you tried a temporary sync?
If you don't know how to do this then all you gotta do is:
* With a Wii remote that is already synced Press the Home Button.
* Pick Wii remote settings, located at the bottom.
* Select Reconnect.
* Press 1 & 2 on the Rock Candy remote and see if that works.
Sadly this only lasts till the Wii is turned off.
I don't know if it works for the Rock Candy remote, but I hope it does until a more permanent solution turns up for you.
Jan 18, 2014 | Video Game Consoles & Games
Tip
How to reconnect Wii remotes to your Wii
There seem to be a lot of people who have had 'problems' with their Wii remotes not working when all they needed to do was reconnect them. Here is a quick guide on how to do this:
When you have turned your wii on press the red sync button next to the SD card slot then press the red sync button on remote(s) under the battery cover. It/they should then be connected. You can then change which one is no.1 or 2 etc. by pressing the home button and going into remote connection and clicking on reconnect.Then press A on your Wii remotes on the order in which you want then (1 first, 2 second etc)
Hope this helps anyone who is having 'problems'.
Mowcius
on May 15, 2008 | Nintendo Wii Console
Sync wii controller tmart
t is possible that your Wii remote has "lost" its sync. You can clear all previous synced Wii remotes with your console and reconnect the ones you are using. Power off the console and unplug the power cord for a few seconds. Plug the power cord back in and turn the Wii back on. At the "Health and Safety" screen, open the small door on the faceplate of the console. Hold the red sync button for at least 15 seconds. All previous syncs have been removed from your console at this point. This process does not need to be repeated to re-sync each remote. Take the first Wii remote you wish to sync and remove the door to the battery compartment. Press and release the red sync button near the batteries. Quickly press and release the red sync button on the console. The lights on the remote will flash and then illuminate the light that corresponds to that remote's position (1, 2, 3, or 4). Repeat this process for each Wii remote in any desired order.
fix it. God bless you
Apr 05, 2013 | Tmart Nunchuk Game Controller for Nintendo...
OK, i got a new wii remote, set it up, and now none of my wii remotes are working including the one i just set up.
Try these two synchronization processes and if it still doesn't work than contact me:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. This procedure must be followed for each additional Wii Remote added to your system.
    One Time Mode Synchronization
Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  1. Select the Wii Remote Settings option from the Home Button menu.
  2. Select the Reconnect Option.
  3. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
PCHELPSTER007 from youtube. If I helped you than please rate me up and if you have any other problems please feel free to contact. Thank you.
Jul 06, 2011 | Video Game Consoles & Games
Remotes can't be found
When you change the batteries for a Wii Remote (in my experience) you have to re-sync (reconnect) them to the Wii console. To do this, there is a button on the Wii Remote by the batteries that either says sync or will show curved bars on I think i red button. This same button should be located on the Wii console. You have to push the sync button on the Wii then on the remote to sync them together. This should solve your connection problem.
Apr 29, 2009 | Nintendo Wii Console
Why are my remotes not working
dont have a wii fit but, try to reconnect the remotes by pressing the button with the blue house on it on the wii remote, and pull up the wii remote settings. then, press the reconnect button on the remote and follow the directions. if that doesnt work, open the battery compartment on the remote and when the wii is on, press the red button inside the battery compartment on the wii remote that says SYNC. if that doesnt work, try the SYNC. button inside the wii itself. (located in the door in the FRONT of the wii. it has a spot for an SD (scandisk) memory card) it is a rectangular bigger button than the wiii remote. even if none of these options work THANKS FOR READING
Apr 19, 2009 | Nintendo Wii Console
We have been playing gutar hero band and now our remotes only work on side how do i fix
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  2. Select the Wii Remote Settings option from the Home Button menu.
  3. Select the Reconnect Option.
    1. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
  • this may reset the remotes for you
    info from nintendos customer service
    Jan 01, 2009 | Nintendo Wii Console
    Wii remote
    Hi Nixo, probably needs re-syncing, press the sync button on the Wii console and the button on the wiimote (under the battery cover), do it pretty much at the same time, the wiimote usually vibrates and one light wll show up.
    Hope this helps
    LesPix
    Feb 28, 2008 | Nintendo Wii Console
    2nd wii remote will not connect with mario play 8
    We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
    This is from www.nintendo.com/wii :
    Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
    http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
      2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    Dec 23, 2007 | Nintendo Wii Console
    Nintendo Wii Console Logo
    195 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
