Error81003005 i hv prob in yahoo messenger signing prob with error 81003005
  • gumshoe0077 Apr 04, 2009
    Cannot log in to Yahoo IM. Had upgraded to ver. 9. Could not sign on. Have uninstalled and installed older version of IM...still cannot sign in. I am now getting the error code 81003005. Tells me it is my firewall. Same firewall not problem before. Now I have to use the Yahoo webmessenger. Don't like it at all.
    How do I fix my sign in? Have changed password several times.
    Gumshoe0077@yahoo.com
    Problem Solver:
  • 12 Answers
See below
Hope this helps
Here's how I solve it:
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
My solution is good only if you have set your proxy server previously in your Internet Explorer. I've noticed this behaviour since in our school, I need to set the proxy server to access the internet. But at home, I don't need to. So when I am at home, this is the normal situation I encounter when I forget to unset back the proxy settings.
On the other hand, the other way around should work. What I mean here is, if you connect to a network that has a proxy server, you need to setup the proxy settings in order for you to use their internet services. Thus, access to yahoo could be established.
[Solution #2]
One area to look also if the proxy is not the one causing the problem, you can check if you have your DNS Server address(es) set, which - in case you have changed your network, can't be accessible to the new network. Thus, it can cause this error.
So, you may unset the DNS Servers (Go to Network Properties >> General Tab >> TCP/IP Properties >> General Tab > Obtain DNS Server address automatically) and try logging in your YM.
[Solution #3]
If the above solutions does not go well, this last one might be the savior. Instead of constantly banging your heads with those re-logins and reconfigurations, you can track back your YM version and replace it with an old version instead. I did this and it works for me well. I had before a version 9 Yahoo Messenger and when I replace it with a version 8, the problem was solved. This should be your last resort if the previous won't work. Remember also to be patient. If it bugs you, don't bug down... bug up!
Posted on Dec 30, 2008
81003005
try two things.
Go to internet options in your explorer. Go to Connections tab and click open lan settings make sure your proxy server is unchecked. than click ok and try again.
If not
this will work.
Uninstall messenger(i know pain in but), and download the new version http://messenger.yahoo.com/
save it instead of just running the program, install it and try it that way.
That is usually and update or proxy error.
Good Luck let me know.
Feb 15, 2009 | Yahoo Messenger
I cant log in to yahoo messenger. theres a sign-in problem.... 81003005. What is this and how can I solve this. Please help.
hi,
try the solution posted on this site:
http://stephenhaim.com/resources/yahoo-messenger-81003005-error
please give me a good rating if solution works for u.
Thanks for using FixYa.
Jan 05, 2009 | Yahoo Messenger
Error 81003005
Yahoo! servers are down for maintenance, the only fix would be to wait.
Dec 30, 2008 | Yahoo Messenger
Yahoo messenger 81003005 error how do u fix it?
New 9.0 version: fix for sign-in issues February 5, 2009 on 1:32 pm | In 9.0 version | 32 Comments
emot_wink.jpgWe released an updated version of Yahoo! Messenger 9.0 today (9.0.0.2128). This latest build includes a fix for the sign-in issues that have been affecting some users. If you were seeing an error code “81003005” when trying to sign in, this latest version should fix that problem. Even if you were experiencing a different kind of sign-in issue, we recommend installing this latest version.
Dec 19, 2008 | Yahoo Messenger
Errror 81003005 wont let me sign in to yahoomessneger
ok, in my case i remembered I tried using a proxy on internet explorer and forgot to put it off, so the proxy connection was still on even though the proxy was dead.
It now a proven fact to me that internet explore settings are linked to yahoo mess!
so make sure your internet explorer is working ok without proxy:
good luck =)
Dec 07, 2008 | Yahoo Messenger
Please try again a little bit later (81003005)
hi,try the solution posted on this site:
Nov 22, 2008 | Yahoo YHT-630 System
Signing in problem with messenger: 81003005
i have a problem error 81003005 how can i remove that error ?
SOLUTION
Make sure messenger is off, then go to start>run> regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
Sep 28, 2008 | Yahoo Messenger
Computers & Internet Logo
277 people viewed this question
David Payne
David Payne
