Question about Frigidaire GLER341A Electric Dryer
Frigidaire Gallery Dryer GLE341AS2; does not turn on. When plugged in, the light inside does not turn on when the door is opened nor does the dryer turn on when dryer settings are place and the power switch is turned to on. could you please help me?
ginko
  • 19396 Answers
SOURCE: Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Posted on Sep 08, 2008
onthejob5130
  • 640 Answers
SOURCE: Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Posted on Jan 01, 2009
thaurfen
  • 623 Answers
SOURCE: Dryer not heating
  • There are two house circuits/fuses in an electric dryer's circuit.
    If one of them is tripped/blown, the drum may turn, but the heater will not operate. Reset the circuit breaker or replace the house fuse.
  • Outlet wired incorrectly.
    Have a qualified electrician verify that the supply voltage is correct.
  • Gas supply valve to a gas dryer is not open.
    Open the gas supply valve. See Installation Instructions for details.
  • LP gas supply tank is empty or there has been a utility interruption of natural gas.
    Refill or replace the LP tank. Call your natural gas utility company.
  • Dryer does not have enough air supply to support the gas burner.
    The dryer needs space around it for proper ventilation. Do not stack or place laundry or throw rugs against the front or back of the dryer. See Installation Instructions for details about installing a dryer in a closet or alcove.
  • Incorrect cycle or temperature has been selected.
    If the Air Fluff cycle or temperature is selected, the dryer will tumble without heat. Each cycle ends with a Cool Down period during which the load tumbles without heat. Check the location of the indicator on the Cycle Selector knob.
Posted on Jan 08, 2009
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
Ben-mrfixit
  • 68 Answers
SOURCE: how to open up Frigidaire GLE0332CAS2???
Try this link, the first one the maytag one has the actual instructions, all dryers a pretty similar you just have to route the belt according to the diagram!! Good luck,, ps a good rating would be nice! thanks
http://fixitnow.com/wp/2004/08/19/appliance-repair-revelation-how-does-that-dryer-belt-go-back-on/
Posted on May 08, 2009
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Makes a ticking or clicking noise when dryer is on. How can I fix it? The heat and tumbler still works though.
Hi Lisa, thank you for your post!
Based on the above-listed model number, FEX831CS it shows you have a Frigidaire laundry center. However, you mentioned that it is a gallery series. So do you have a laundry center or a Frigidaire gallery dryer? In order to better address the issue, what is your model number? You can typically locate the serial tag, which lists your model number, on the right or left edge on the inside of the door. How often do you hear the ticking or clicking noise? With this information I can better assist you. Thank you!
Dec 12, 2013 | Frigidaire FEX831CS Top Load Stacked...
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
Dryer will not turn
hello check to see if the long pin inside the door has not snaped off if thats ok .then check capacitor next to the motor inside the dryer may have blown
regards
shaun
Mar 01, 2010 | Frigidaire Electric Dryer
Dryer problem
Your dryer drum front support glides and rear drum bearing needs to be replaced, parts are not expensive but labor to do the job may be $50 to $100 dollars.
You should call Frigidaire customer help line just to gather some info from them. 1-800-FRIGIDAIRE
Good luck !
Jan 05, 2010 | Dryers
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
Feb 01, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not start
open door spin drum and close door and start unit your motor has a dead spot
Sep 20, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLER341A Electric Dryer Logo
101 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
