Question about Toshiba W522 VHS VCR
This model is the W528 VCR, but my manual includes both models
Hello, I have a problem with this vrc making the picture roll all the time. It may or may not be a problem in recording, but it is absolutely a problem in play back. Can anyone tell me how to fix this problem? Thank you. Azor
    Novelist:
    Champion:
  • 275 Answers
First check vertical hold control on your Tv. If iot is ok - ie. the picture does not roll on your broadcast picture, then check the VCR. Are you playing old tapes? If they are old, or if your VCR is old, it is possible that your VCR is chewing the tape. Flip the tape cover flap of your cassette and see if the lower edge of your Tape is OK? If it is chewed up, then the Control pulse signal has been damaged. Cheweing of tapes happens when the Capstan pinch Roller is old. replace the Roller.
Posted on May 03, 2007
    Novelist:
    Champion:
  • 254 Answers
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
Posted on May 02, 2007
SOURCE:
The picture looks like it has a lot of squares like when it is raining and we get rain fade then it blinks and makes a sqreaching sound
Hello! Dan Busa here with DISH N etwors customer service department. What your getting is absolutely signal loss it dounds like you will need your dish realigned. The screaching sound you're referring to may be a sign the box is bad. If you'd like further assistance, feel free to e-mail me at: daniel.busa@dishnetwork.com
Sep 20, 2010 | DISH Network DVR-625 DTV Receiver /...
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
VHS Video Tape - Picture Roll.
Picture roll is caused by the frame rate being out of sync with the play back device. If the tape was recorded at say 25 f/m and is being played back at 26f/m. If you can, adjust the frame rate until the picture stands still.
Mar 30, 2010 | Philips VRX242AT VCR
On my vcr slv-770hf on play back it jumps and rolls also the sound is low,records real good.
try using a head cleaning kit on the vrc. Or adjust tracking if needed.
Mar 04, 2010 | Sony SLV-998HF VHS VCR
Rolling picture and blue screen
According to my Satellite provider tech support. More and more channels are being encoded so that recording equipment cannot capture the signals to prevent piracy. I know the premium channels use this technique now. I would call and ask tech support if there is any copy restrictions in place that would affect your VCR recording before doing any further trouble shooting on the VCR. If you can play pack a prerecorded movie fine with your VCR then it should also record fine. Also try watching the channel through the VCR tuner and I bet you will see the same pattern. The VCR can only record the signal it is given.
Hope this helps you,
Ron
Feb 24, 2010 | Samsung DVD-V5500 DVD Player/VCR
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
How to change region code on Toshiba D-VR3 player?
1) In DVD mode,press System Menu.
2) Go down to the Lock icon.
3) While lock is highlighed, press 0 for seven times (o,o,o,o,o,o,o).
4) There will be a pop-up window that asks you to confirm.
5) Press ok.
Jay
May 21, 2009 | Toshiba D-VR3 DVD Recorder/VCR
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Setting VRC to timed recording.
I suggest that you record one month at a time.
May 08, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Playing slp mode picture rolls
the video and control heads are probably dirty. a video cleaning tape might work, otherwise you will need to get a proffessional to clean if for you.
Mar 25, 2008 | Philips Magnavox 20MC4304 20 in....
Toshiba W522 VHS VCR Logo
257 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
