When i play music loud the sound cuts out
When i play any music loud it keeps cutting out. I have made sure that the amp is ventilated and the speaker wires are securely plugged in. Not sure what else it could be. When it cuts out i have to turn it off and turn it back on again and it works. Please help.
Thanks
Adele
I would try getting a new amp, the speakers may be blown.
Posted on Dec 30, 2008
I have the infinity rs8a tower speakers and they sound good but when I turn the volume up the subs turn on and off on both towers
When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
Mar 17, 2014 | Audio Players & Recorders
My Behringer 2500 wat pa amp keeps getting hot and cutting off
Step 1:
Overheating is typically caused by poor ventilation. The best thing is to make sure that you --
Step 2:
have plenty of space ALL-AROUND the amp
Step 3:
Fan(s) are working correctly (should always be on).
Step 4:
Boards are clean -- may require opening up housing and spraying with compressed air.
Step 5:
Be sure that the speakers you're pushing are acceptable to amp's output.
Step 6:
If still overheating, may require service.
Jan 07, 2013 | Behringer Music
After driving for about thirty minutes my amp will just cut off, it seems a little hot and then it will turn back on in about 10 minutes. I'm not playing my music loud at all and I have all kenwood...
sounds like your speaker is either the wrong resistance for your amp ie your amp may state 4 ohms and your speaker is 2 ohms which means that the speaker is shorting out the amp and its going into protection mode or the speaker could be burning out and shorting out the amp
May 30, 2011 | Car Audio & Video
When i play a bit loud (not too much though just when the light blinks red on the hard play) the sirquit closes the amp for two seconds.can you healp me on this ?thank you very much
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
Feb 08, 2011 | Ibanez P500H Promethean Bass Amplifier...
Fender Frontman 65R Solid State guitar amp. After a while whether playing loud or not,it cuts out. Switched on when cold,it works again with no issues at all,but it starts cutting out again when hot. Same...
There is a protection thermistor in the circuit to keep it from over-heating, this is why it works again when it cools. Check and make sure you are not covering any ventilation holes, or if the unit has a fan, make sure it is working.
Aug 14, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Pdx 4.150 amp suddenly cuts all sound from the amp when music is played loud/normal for me, unknown reason it just started doing it, I didnt change or add anything to cause this issue. All power and ground...
ALL THAT IS NOT YOUR PROBLEM CHECK ALL YOU POWER SOURCE AND IF ALL OK CHECK TO SEE IF ANY SPEAKER IS BAD OR GROUNDING OUT'' THE CAN COURSE THAT TO HAPPEN AND CHECK MAKE SURE RCA IS NOT PINCH ANY WHERE
Aug 05, 2009 | Alpine PDX-4.150 150W x 4 Car Amplifier...
Technics su z2 amp shuts off sound
hello. we cant help if we dont know what music source you are using.
Apr 13, 2009 | Technics SA-AX530 Receiver
My Boss Amp keeps cuts off when I play the music from my stereo
check your ground wire and your remote wire, Wiggle them separately both at the amp and at the ground point. See if it cuts out then, and you;ll know which one. Also, does it have a light on it when it cuts out? if so, it could be going into protect mode, which wont allow it to turn on for a period of tine. Make sure the amp is not too small for the speakers you are pushing.
NGK
Sep 03, 2008 | Boss Car Audio & Video
Probvlam with my cambridge audio 640 a cutting out
Check operations manual for indications as you described. Amps MUST have adequate ventilation. Make sure unit is not in small, semi- closed space or on top of other warm equipment. Check for speaker impedences match that of amp
May 29, 2008 | Cambridge Audio Azur 640A Amplifier
Speakers All Cut out Including Sub When Music is Played Loud
UNPLUG THE GREEN WIRE FROM THE COMPUTER AND PLUG IT INTO A CD PLAYER IF IT WORKS BETTER ON A CD PLAYER THAN THE COMPUTER IT SELF THERE MAYBE A PROBLEM WITH THE SOUND CARD AND ALSO TRY THESE STEPS I AM GOING TO GIVE YOU I AM SURE ONE OF THEM WILL WORK.
1. Please ensure that the all the connections between the satellite speakers and the subwoofer are firmly connected.
2. Next, please connect the green colored 3.5mm audio jack to another audio device such as an iPod or an MP3 player.
3. Ensure that the SoundTouch remote control is firmly connected to the back of the subwoofer.
4. Connect the power cord from the subwoofer and connect it to another single power outlet in your house. If you have an automated voltage regulator (AVR), please connect the power cord through the AVR instead of connecting it directly to a power outlet in your house.
5. Power up the speaker system and check whether the power button on the SoundTouch remote control will light up.
6. Turn on the Matrix Mode ON. This option is on the SoundTouch remote control. This is to ensure all speakers from the speaker system will produce audio that will be played from the audio device.
7. Play audio from the audio device. Check and see whether the all the speakers will produce audio being played from the audio device.
IF NONE WORK TRY THESE STEPS:
Jan 12, 2008 | Logitech Z-5300 Computer Speakers
111 people viewed this question
 Grubhead
Grubhead
