Question about Eureka Whirlwind Litespeed 5740 Bagless Upright Cyclonic Vacuum
Dust blowing out of the side of vacuum
The vacuum has good suction and picks up well, but dust blows out the side where the allergen filter is...which I would assume is there to keep that from happening.
I took the filters out of the filtration unit and cleaned and dried both of them and replaced them and added a fabric softener sheet on top just to see how much dust was getting in there. One sweep of the floor and the sheet was filthy as well as the 2 clean filters and the outside of the vac. cleaner was all dusty. I have grandchildren with allergies so this is a real concern to me
  • 76 Answers
Make sure that the filter in the dirt cup is in place.
Posted on Apr 19, 2009
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
There is suction when we have the filter basket off but when it is attatched there is no suction
the filter tube is clogged , I know it takes time but use either damp rag over filter holes or try blowing into holes I find gently tapping and blowing help also swifter dusting cloth helps unclog it
Oct 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Has my Dyson lost suction??
just wash the filter on the top of the cyclone every 6 months.
Nov 14, 2008 | Dyson DC14 All floors Bagless Upright...
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Loss of suction, loud blowing noise
Hi.
Try cleaning out the vortex this will sort out poor suction.
http://dysonmanuals.llc.nu/
Oct 16, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Whirlwind Litespeed 5740 Bagless Upright Cyclonic Vacuum Logo
775 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
