Question about Dryers
I have a Whirlpool GEW9200LWO Electric Dryer. A couple of weeks ago it started throwing the breaker about 10 minutes into the cycle. I spoke with a repairman and he suggested that I have the breaker replaced. I did, now when I try to start the dryer there is a click and it the censor light comes on and thats it
I have a Whirlpool GEW9200LWO. i just moved into a house that only has 110 set up in the laundry room. can i convert my 240 to 11o. is there an adapter?
Posted on Jan 18, 2010
  • 91 Answers
Check to see that there is nothing rubbing or hitting fuse,thermostats, that the only thing that trips dryer (like change)
Posted on Jan 03, 2009
The breaker blows if you open the dryer door after about 10 minutes into the drying cycle
dryers use 30 amp breakers, I would buy a new breaker and see if it fixes the problem. Good Luck Tim
Nov 26, 2010 | Whirlpool GEW9250 Electric Dryer
My whirlpool dryer is not turning on when i try
Can you be more specific? Is it gas or electric? I don't want to patronize, but are you sure the breaker didn't trip? Does it make any kind of noise at all? Are there any kind of smells like electrical burning smell? A couple of things could cause your problem. You could have a know between cycles. the start switch could be bad or you just may not have any power. Be a little more specific please
Feb 16, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer is flipping breaker after 10 minutes into dry cycle.
You have a weak circuit breaker . Should be a 30 amp or higher . If you have access to an amp meter , split the dryer cord , separating the 3 wires (do not remove the insulation ) . If you have a black round cord ( 4 prong ) , carefully slice into and remove the black insulation in a small portion only . Check the amps on both outer wires while running dryer . Make sure the amps being pulled are lower than the circuit breaker amps . On a black cord , test the black wire and the red wire amps . If the dryer has a short , it would not run for 10 min and then throw breaker . It would be almost imediate . A bad breaker will gradually get hot and then flip , but check the dryer amps anyway to be sure .
Aug 15, 2009 | Estate TEDX640JQ Electric Dryer
Shuts off after 10 to 45 minutes
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Whirlpool 6.5 Cu. Ft. 5-Cycle Super...
Whilpool Dryer Won't Run
you have a bad saftey swith inside te dryer this cost anyware for $8.00 to $ 15.00 for the part
Feb 01, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool Dryer stopped mid cycle and won't start again
This sounds as if the internal fuse has blown. I am assuming you have checked the breakers as well. The starter switch might be bad.
Dec 24, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool GEW9200LWO Elec Dryer
just check the fuse and plug pin connection in it
Jul 18, 2008 | Whirlpool GEW9200L Electric Dryer
Whirlpool Dryer not heating
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
MY CONTROLS ARE LOCKED
Press and hold the End of Cycle button for 3 seconds.
Jun 05, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
274 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
