Question about Sony VPL-ES1 Multimedia Projector
I have a projector (SONY VPL-ES1) and the bulb stopped working. Took the bulb out, and not sure if it's blown or not. I checked online, to see if anyone else had similar problems, and sure enough they did. I read one that said it wouldn't just stop working, it'll dim out eventually, not just in a matter of seconds. And plus when you fire the projector up, it just shuts down, it doesn't stay on with the fan running, etc. Any additional help would be greatly appreciated, thank you.
    Problem Solver:
  • 5 Answers
Usually the projector powers and cools down. if you restart it it will open the cover, not projecting anything and after 10 seconds it will close again. this happens if the lamp is shortly before the end of the measured lifetime (no fixed hours) to protect the projector. usually if you take it out once or twice it will work for 1 or 2 more times but the bulb is very likely to explode (not destroying the projector but not good anyways)
Posted on Aug 04, 2009
How to fix the big dark circle in the middle of the screen
I think you may be having a problem with the projection bulb.
Jun 09, 2014 | Sony VPL-ES1 Multimedia Projector
I have a Sony VPL-ES1. After I had moved my beamer from the first to the second floor it won't power on. It's connected to the power well. I've had this problem before but I would like to know...
ensure that the projector goes through the cool down cycle, for example the fans stop running, before you unplug it. Unplugging it will cause it to into power failure mode which will not allow the lamp to turn on until the bulb reaches ambient temperature. it will also extend the life of that very expensive bulb. take the extra time to let it shut down before you unplug it.
Jul 02, 2011 | Sony VPL-ES1 Multimedia Projector
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
VPL ES 1 LAMP RESET
i have replace lamp but stlii no picture coming through
Sep 23, 2008 | Sony VPL-ES1 Multimedia Projector
Reset after using emergency close feature
Hi jimmac123
Where exactly in the UK are you ? I'll try and locate another - more helpfull company.
May 20, 2008 | Sony VPL-ES1 Multimedia Projector
Sony VPL-ES1 projector
Hi Max
Is there any power on the unit at all ?
i.e. Does the LED's on the unit indicate that it is in stanby ?
If it isn't then it could just be a fuse that has gone on your Powersupply.
Apr 21, 2008 | Sony VPL-ES1 Multimedia Projector
Blue Bleed
Hi there
Does this only happen once a signal is inserted ?
Does it happen on both PC & Video signals ?
Have you tried using a different cable yet ?
Apr 16, 2008 | Sony SuperLite ultracompact Project...
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
Blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
May 13, 2007 | Sony VPL-ES1 Multimedia Projector
Sony VPL-ES1 Multimedia Projector Logo
259 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
