Question about SanDisk Sansa e250 MP3 Player
When i run the file it says;
Frm where to download firmware for e250...is it same for e200....i hav downloaded a file frm the link below http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe but when i run the file it says; " ERROR ! application failed to read the version details." what do i do help plz............... deep_y2006@yahoo.co.in
  • 8,596 Answers
Try again
Posted on May 26, 2008
My sansa e250 having video option, but it not supot any video file to play on the player.
When your operating system on the computer is Windows:
Run the Sansa Firmware Updater to get the Sansa Media Converter: http://kb.sandisk.com/app/answers/detail/a_id/101/related/1
When your operating system on your computer is Mac, or when you want to update manually:
go to the Sansa forum: http://forums.sandisk.com/sansa/board?board.id=e200
note
Only when you have the e200 series version 2 player, videos can be viewed from the microSD card.
Accessing the microSD card:
http://kb.sandisk.com/app/answers/detail/a_id/167
Highest capacity of the microSD card:
Verify the version of the player. To check, go to Settings > Info.
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
Differences between e200 version 1, 2 and Rhapsody player:
http://kb.sandisk.com/app/answers/detail/a_id/193
For supported files, see:
http://kb.sandisk.com/app/answers/detail/a_id/21
and
http://kb.sandisk.com/app/answers/detail/a_id/32
Aug 13, 2010 | SanDisk Sansa e250 MP3 Player
Refreshing database
User guide for Sansa e200R:
http://mp3support.sandisk.com/downloads/um/e200r_userguide_en.pdf
Check this link for Sansa e200 "freezing in refreshing database",
2 steps to follow up:
http://kb.sandisk.com/app/answers/detail/a_id/34/kw/e200r%20freeze/r_id/101834
1. Reset the device as described on the site of Sandisk.
http://kb.sandisk.com/app/answers/detail/a_id/189
If resetting didn't solve your problem
2. Update the firmware.
http://kb.sandisk.com/app/answers/detail/a_id/306
2.1 Use the Sansa Firmware Updater for a download of your device
with the next link:
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
2.2 Follow the instructions "update the firmware" for sansa e200 series:
http://kb.sandisk.com/app/answers/detail/a_id/306/kw/e200r%20freeze/r_id/101834
Sep 20, 2009 | SanDisk Sansa e250 MP3 Player
No operator's manual for e250
Here is the link - a Sansa e250 has a Sansa e200 series manual:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200_userguide_en.pdf
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
Is there a manual on how to operate the sandisk sansa e250
It is available from Sandisk's website - go to the website, click on Support, Download Center, mp3 players, e200 series:
or here is the link:
http://www.sandisk.com/Assets/File/pdf/guides/e200/e200v2_userguide_en.pdf
-Tha Mp3 Doctor
Dec 17, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250R firmware
hey yeah i had the same problem with my sansa e250r. when mine does that i
1. turn it off
2. put the hold button on
3. hold down the rec. button
4. turn it back on
that will get you into recovery mode connect your data cable once you have hooked it up to your computer open my computer and you should see a 16mb drive there instead of your normal mp3.
once you see that open it up.
now go to http://www.sandisk.com/Retail/Default.aspx?CatID=1449 scroll down and click on download firmware link
once you have downloaded that file unzip it and copy the file that is inside to the 16mb drive that you opened up in my computer.
once you have done all the above,,
1. take the hold button off
2. disconnect the data cable
3. wait for it to reboot.
if the above dosent work you might wanna take it to the dealer.
hopefully this works for you as well as it did me. good luck
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
It just died and the instructions worked until a certain point
Our player had died after we re-formatted it and forgot to update. oops. =) but this worked. Thanks much for the post.
the follwing link supports these sansa devices.
Devices supported:
e200
e200R
c200
m200
express
Clip
View
( I did exactly what was posted, new link if you don't already have this on your pc. http://www.sandisk.com/Retail/Default.aspx?CatID=1376 )
  1. Turn the switch on the top of the player to 'Hold'
  2. Press the Record button and Menu buttons at the same time until it the player boots (this took a few seconds)
  3. sansa e200 should tell you to move the switch to unlock,
  4. connect it to your pc and it will update the firmware.
Oct 26, 2007 | SanDisk Sansa e250 MP3 Player
Sanse e200 freezing up for no reason!!!
Hi. It seems like your player decided to throw a hissy fit by deciding to experience internal system errors. Best that you reset the firmware. Here's how: Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Step 5: Enjoy using your Sansa E250, just like I do. (I love this player)
May 14, 2007 | SanDisk Sansa e250 MP3 Player
Sandisk sansa e200
I had this same problem on my sansa and tryed the previous solution with no luck. Out of frustration i email the sansa technical support. Try these steps to format the player: -Turn on the player and access MENU > SETTINGS > USB > MSC - Once the player is set to MSC mode, reconnect it to the computer and open the My Computer window. - Once you see the Sansa icon in the My Computer window, right-click it and choose FORMAT - In the Format window, choose FAT 32 and make sure that Quick Format is NOT selected, then choose START -Once the format has completed, disconnect the player from the computer to allow it to refresh. If you plan on using Windows Media Player to transfer files, return to the USB menu and set the player to MTP mode. Otherwise, leave the player in MSC mode and you can now resume transferring files. Formatting your player will deleate all files but you can putt them back on!!! Best of luck!
Apr 25, 2007 | SanDisk Sansa e200 MP3 Player
Plz help =(::::::::::
Hi Blkmage. It seems that your E250 is experiencing some system errors due after the format due to some bad tracks on the player. Try this solution, but this solution is only meant for the "Standard" E200 players (there are 2 types of E200 players -- the Standard E200 and the "Rhapsody" players, indicated with an "r" after the E200 such as "E250r". I'm hoping you have the standard E250. Switch your Sansa E250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E250 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred which caused the "Load Main Image Failed" notification in the first place. Step 3: When the process is complete, unplug your E250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E250 and 90-99% of the time, it would boot up successfully. Hoping it works out for your player. Syd :)
Apr 22, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E250- Only the blue light comes on? HELP????????????
Try this: Switch your Sansa e250 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the e250 LCD screen displays "Welcome to Recovery Mode" (if the LCD remains black, keep pressing long enough -- about 10 seconds -- then proceed to the next step) 5. Connect your e250 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa e250 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the e250 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa e250 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downl... or use this Sansa Firmware Updater link: http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player (or find the most updated firmware) and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your e250 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your e250 and 90-99% of the time, it would boot up successfully. I hope this helps.
Apr 20, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
66 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
