Question about RCA RT2250 System
RCA RT2250 consistant shutting off in Satalite mode.
I can have the Fm tuner on and it plays for hours. I have the Satalite going thru the VCR and it plays for hours. As soon as I push the Sat button on the Receiver it shuts off 5 to 10 minutes down the road. I had it going for 30 minutes from a cold start the other day now all it wants to do is shut off. What is wrong? It started out by turning off and turning right back on. Now it doesn't like to stay on. If you can help me Please do, because the feed thru the VCR isn't the best. Thank You for your help.
  • 1 more comment
  • Shelley King May 15, 2007
    Also if the volume level goes over 40 or you change it to stadium or any other beside stereo it will shut itself off even in VCR mode.
  • cybersweet Nov 23, 2007
    My RT2250 will stop transmitting sound through the speakers and then turn off with the greeting sign scrolling by. If I play with the Bypass button, it will for for a few minutes and then turn off again. It was working great but now it won't work :-(
  • Anonymous Jan 05, 2008
    Mine stays on for about 45 seconds then shuts off and it will not play any sound when I use VCR or DVD or TV or Tuner. I do thank you for your time. Joe Hart
Mine will always just turn off every minute or so after a hard shut down(ex: power outtage). I have to turn it back on and then hold the set button for a few seconds, then it stays on, until i turn it off manually, since the remote won't turn it off.
Posted on Dec 30, 2007
I have a Sa-ex900 amp hooked up to Television ,vcr and dvd player. When I turn the amp on and want to play the tuner , the television bleeds through. In fact TV plays through all buttons except VCR1
it seems to be ,you have a possible wrong connection..I
may I recommend you to check the connections in accordance with my model connection procedures given below and correct if something is misconnected..
I believe Your Television ,vcr and dvd player all connected to each other thru Technics Receiver itself (not directly connected to each other ) and whenever you want to listen/watch any of it ,you make a selection thru Receiver..
** in order to do this both DVD and VCR 's "2xRCA audio" and "1x RCA Video" cables for "IN" and "OUT" should go to Receiver separately ..("IN" goes to "OUT" of other ..pls remember,Always reverse connected )
** Additionally your RECEIVER's prefably only "1xRCA Video Output " should go to TV to watch the video of both DVD and VCR (audio will come thru Receiver.)
Ok, now Since you successfully connected your Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV .( every TV has different type of Audio out jacks )
** to "TV input "or "AUX input" or "Optic Cable input"
of your Receiver (whichever you want ,based on the necessary cables on your hand )
** than just switch to respective mode on
Receiver corresponding the connector you have used on the back of Receiver ..
There you go..Tv sound are on the
Receiver .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 07, 2011 | Technics SA-EX900 Receiver
Rca rt2250 no sound
please give us more details, I don't know what reciever you want to use? AM,FM? or some other devices.
but if it's the am,fm reciever well you can find it in your instructions manual how to set it though.
just follow the steps and you will have it..
have a nice tunning
just don't rate me badly^^
ps:
make sure your antenna is connected properly..
Feb 17, 2008 | RCA RT2250 System
Rear speakers not working
Your FM tuner will only generate sound from the front sepakers. CD's, Tape, and I guess mp3 player, as well, will only play through the front speakers.
I've included a link for the manual. The audio on this rig is pretty complex. read through the info, especially pages 11,12,13, and play with the audio controls.
http://support.radioshack.com/support_audio/doc61/61792.pdf
Aug 16, 2009 | RCA RT2500 System
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
I have a RCA RT2250 and I have a green light on a circuit board
Check the solder connections on the seven voltage regulators found in the center of the receiver on the heat sink from front to back (not the amp board) they are on the main board. The green light on the DSP board (back right side) is an error light. You can reset the receiver by pushing power then stadium then night then dsp off then club after unplugging the receiver and plugging it back in.
Hope this helps,
JohnW
Jan 10, 2009 | RCA RT2250 System
No sound
make sure the optical,analog, or coaxial settings are right for each component
Mar 15, 2008 | RCA RT2250 System
RCA model f32649
Hi, Based on your post/description, it would appear that the TV tuner of the RCA is at fault. Chances are the the VHF Low is not working right but the VHF High is. This is an inshop repair probably requiring component replacement. You may want to confirm by checking your TV's setup in the menu, you should have Cable selected instead of Air or STd and do a Memory + (scan and add channels). If still a no go, then back to the tuner suspect. The VCR will not display any movie since it normally transmits in Channel 3 (which is VHF Low). If there are no other problem with the VCR then you might still be able to use it by connection it to the A/V inputs of the TV. If the VCR works in A/V mode, then perhaps you may want to save the repair expense of the RCA TV and use the tuner of the VCR to watch TV and switch channels. Post back should you need additional information. Good luck and kind regards.
Aug 23, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Stero keeps going in and out
Is this noise in the Tuner position only or in all inputs? Need more info to diagnose.
Jun 09, 2007 | RCA RT2250 System
RCA RT2250 System Logo
163 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
