Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
UF-885 Panafax We had a low toner last week. We replaced the toner and got the error message AU Opt 3. We pulled the new cartridge out and were able to make outgoing faxes. Today the fax reads "phone off hook". There is a dial tone for the phone and it is working. We still have no print out of faxes, and now we can't send a fax either.
  • Machteld Jan 08, 2009
    From one day to the next (no one touched the machine in the meantime) it suddenly reads "Phone off hook and it won't send or receive anything!
    Help!
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 11 Answers
The instructions above will get you back up an running again but its not a solution to the problem.
You should have a Panasonic tech come out and confirm these 2 items:
The 885 had a unique problem where they came from the factory with missing noise filters on 3 of the power harness of the FCB board. Confirm that the machine has been updated with the noise filters. Otherwise any static discharge or high voltage spike from a damage toner cartridge could cause it to lockup again.
Also confirm that the unit has the most current firmware version
UF-885BLV39501
Posted on Mar 22, 2009
    Genius:
  • 2,120 Answers
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
scroll down to SHIPMENT SET
press SET or START
press 2
wait for the machine to reboot.
Posted on Jan 18, 2009
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Machine totally unresponsive just blinks model with letters AU after it" for model UF 885
Remove the toner cart
Pull up on the operation panel to open
unplug the machine
hold down the pointed switch near the **** glass while plugging the machine back in.
wait for the beep
close feeder
press SET
press 2
press SET
wait for the machine to initialize
Jun 15, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Replacing the LCD battery on a Panafax UF-885
Open up the document feeder by pulling straight up.
You will see a white tab sticking out of the black base.
Push FIRMLY towards the rear with your thumb.
The battery is a CR-2032 as printed on it.
Feb 02, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic copier/fax UF 885
It sounds like you are stuck in the boot-up mode.
Try this:
Open the toner door and remove the cartridge
Turn the machine off
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Sep 19, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax uf 780
Make sure you have not installed a Toner Cartridge made for the Panafax 585/595 or one for a Kyocera-Mita KM-F650.or Pitney Bowes
It should be UG-5510
The all look identical.
Jul 24, 2008 | Panasonic Panafax UF-780 Plain Paper Laser...
Panfax uf 885
If it happens on all printouts, and not just from one sender, then replace the toner cartridge. That will clear up most image related issues.
Jan 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Machine will not reset after toner replacement
Info code 45 really means Toner cartridge is not installed.Info code 41 is out of toner & code 43 is toner getting low. There are three connection points inside of the fax machine that tell the machine that a cartridge is installed. Open the cartridge door & remove the cartridge. Verify that the metal tabs on the right hand side above the drive gear stick out far enough to make contact with the cartridge. There should also be two wires that are located on the left hand side that also make contact with the cartridge. Try putting your used/empty cartridge in & see if your info code changes to a 41 or 43.If not, you may have a broken connection. I have found that some compatible cartridges for the panafaxes are missing metal tabs that make contact with the connectors. Compare a cartridge that worked to the one that doesn't to see if it's missing metal tabs. This is not an issue if you are using OEM. Good luck! I can be reached by email if you have any questions. bspier@carlsonsupplies.com
May 23, 2007 | Panasonic Panafax UF-885 Plain Paper Laser...
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
238 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
