Question about Minolta DI-2010F Copier
Konica Minolta Copier
Is there a way to tell if my 2020 copier has a twain card?
Thank you,
Paul A.Baldovin
    Genius:
  • 1,011 Answers
Sir,
I can't understand your question. Tell me elaborately. also click this link
thanks
good luck
Posted on Dec 30, 2008
  • 916 Answers
Generally if the copier is also a scanner it using a twain driver.
How do you do firmware on a konica minolta bizhub 282 is there a particular way to do so other than the manual method?
Normally firmware is located on a secure web site, If you have the manual it will tell you. Recommend at KMBS tech do it messing with the copier OS is not good.
Sep 21, 2016 | Konica Minolta bizhub Office Equipment &...
When turn on the machine the error code c-c170 indicates
NVRAM and or MFP Board failure. Recommended you get a qualified Konica Minolta Tech out to correct. as The Firmware for the machine may need to be re-flashed. The firmware is at a secured website, for Konica Minolta Technicians. The board might also be bad. the NVRAM is memory that stores major info on the copier. The code is telling you not enough memory for the MFP board or that the MFP board is having issues. MFP are not cheap$$$$$$$$$$$$$$$$$$$.
Jun 11, 2015 | Konica Minolta Bizhub c203 Copier
Reset image unit (Magenta) Konica Minolta Bizhub C352
Change the chip or enter in service mode and change the imaging unit life duration to long life.The copier displayed continuosly Please change the image unit,press OK and ignore.
Feb 13, 2013 | Konica Minolta bizhub Office Equipment &...
Necesito driver de escaner de bizhub C350, no se si me podras ayudar solo del escaner por que tengo de printer
Hola buscalo en la pagina de konica Minolta driver en support es que esta nombrado como twain
Aug 18, 2010 | Minolta C350 Color Printer/Scanner/Copier
Install preventive maintenance kit for Konica copier
hi yes U can see konica minolta sit Ucan downlode users and GO
Jun 04, 2009 | Konica Minolta Minolta DI1610FP...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scanning documents
You have to install driver with software, you can get it from www.konicaminolta.eu
Also you can scan with MS office or other Windows software, if you installed Twain scanner driver.
Find driver and software link below:
http://download2.konicaminoltaeurope.com/openmind/technic/kmbsdwl.nsf/psearch?openform&ch=MFP&dist=BEU&ui=en&dg=sw&prod=Di1610&dsg=&os=&lang=&ml=0&rid=&sub=&pcat=&pcc=
Nov 14, 2007 | Konica Minolta Di1610 Copier
Minolta DI-2010F Copier Logo
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
