Question about MSI Wind UmNotebook
Wifi saying limited or no connectivity
I have done the update on off windows from the other post.
i basically rebooted the computer with the xp service 2 cd and everything was wiped clean. so i installed the wireless driver again but it just keeps saying aquiring network address and than limited or no connectivity.
i am using a safecom swbarr 5400 router. it all worked fine before i rebooted it and my other laptop works fine.
I tried this solution
First check to see if there is any wireless secuirty on your router and if so, set the secuity to NONE and while your at it, change the channel on the router (IF you can... dont worry if you cant as not all routers are easy to change chanel) plus if there is a friewall or anti-virus enabled (EITHER on your computer OR on the router) then disable it.
IF THAT DOES NOT HELP.......
Second...
From you CONTROL PANEL click on “Network Connections” then click your connection.
Next RIGHT CLICK on the connection it shows you and a pop-up window will appear. Choose PROPERTIES.
That will open a "Local Area Connection properties" window. You will find a box showing different icons look for the one which says Internet protocol (TCP/IP). When you have found it highlight this and click on the property button below.
A new window "Internet Protocol (TCP/IP) Properties" will appear from this window and you have to make sure that the following options are selected:
1."Obtain an IP address Automatically"
2. "Obtain DNS server address Automatically"
If they are NOT selected then select them and then click OK.
It will now take you back to the previous window again click apply, OK and close.
Reboot your computer and you should be good to connect.
And this solution
Please follow these steps
Click Start >Run >regedit {enter}
Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Winsock and delete it; just below that, see HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Winsock2 and delete it
Exit Regedit and reboot.
To Reinstall TCP/IP
To do this you need a copy of nettcpip.inf. There is one on the Windows XP CD and there may be one on your hard drive at C:\WINDOWS\inf\nettcpip.inf. Note: To see the inf folder, open My Computer and go to the menu item Tools > Folder Options... > View > and choose Show hidden files and folders.
Right click "My Network Places" select Properties.
Right click the connection(s) and select Properties.
Click Install >Protocol >add >have disk.
Browse to the location of nettcpip.inf .
Select nettcpip.inf then click Open then OK then Internet Protocol (TCP/IP) then OK then Close
Reboot
But none of them worked.
  • Michael Ward May 11, 2010
    need more info to solve your problem.
    I would need to know what version of windows. Is the wirless router protected or not. Where is the computer at and the router is located
  • Tim Hallman May 11, 2010
    Do you see any other networks (preferably unsecured) when you search for networks?  If so, can you connect to any of them?
    Have you disabled the this network requires authentication checkbox in your wifi configuration?
  • 33 Answers
Sounds like you have a bad piece of hardware. Can u surf with a hardwire to router? I would consider purchasing a wireless usb adapter and installing it to test with. The winsock repair that you performed would only fix a browser related issue. I doubt that you have mac address filtering enabled on your router, but if you do then that would explain why you cant connect. Then again you would be able to connect to other networks, just not yours. Hope this helps...tennis123
Posted on May 20, 2009
2 Suggested Answers
Iceman999
  • 45 Answers
SOURCE: wifi is saying limited or no connectivity
Hello Rifaaqat,
Ok this could be several things, but lets list them in order and if you follow these instructions you should be able to connect ok.
To start.....
Second...
As a final note, if your having any problems accessing your routers on-line interface remember that the defualt username and password for logining in to it is normally set to “admin” and “safecom”
Hope that helps you, so please leave a rating so I know if it has.
Good luck.
Posted on Dec 30, 2008
I HAVE COMPAQ LAPTOP PRESARIO CQ60 IT WONT CONNECT TO INTERNET ON MY WIRELESS NETWORK, I BELIEVE ITS MISSING THE LLDP NETWORK PROTOCOL DRIVER
had this laptop myself, you need to remove all the drivers for the wifi and delete the files and folders.. download the driver from HP, reboot the laptop and it should install the windows driver. reboot again and then install the HP driver, when you have done this and its working make sure windows cannot update drivers ever again as windows installs wrong drivers. windows 10 is prone to installing the updated drivers that are not compatible with this model. like mouse pad. max version is 18. windows puts 19 on and it makes over driver incompatible.
Mar 12, 2018 | Compaq Computers & Internet
Tip
Increase your internet speed up to 20% in Windowx XP.
If you use Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks.
If you want to tap into this locked speed then make the following changes:
1. Go to Start-> Run-> and type gpedit.msc
2. Expand the Administrative Templates branch
3. Expand the Network tab
4. Highlight QoS Packet Scheduler
5. Click on Limit Reservable Bandwidth and check the enabled box
6. Then Change the Bandwidth limit % to 0 %
Once you have done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
on Jun 19, 2010 | Computers & Internet
AFTER RESETTING IT SAYS CODE ERROR WONT LET ME CONNECT TO WIFI
Resetting as in clean install or just rebooting? If in the case of resetting you may need to reinstall your wifi driver from your computer maker's website. After that, windows update should download your other required drivers.
Feb 16, 2016 | Computers & Internet
How do I stop continually trying to connect to wifi and failing
Unable to Connect to wifi problem - Solved for me ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Jun 7, 2012 - I tried the "forget the connection" workaround but it always came back. ... recognizing and joining the wireless network, but are not connecting ... Ipad won't connect to wifi after update iOS 7.0.6
Mar 1, 2014
New iPhone 5s - constant "Incorrect WiFi" password
Nov 25, 2013
Wifi ISP keeps failing
Sep 10, 2013
New Macbook Air - wifi connectivity problems
Jun 13, 2013
More results from discussions.apple.com
How to fix limited or no connectivity Wi-Fi issues in Windows 8
www.fixedbyvonnie.com/.../how-to-fix-limited-or-no-connectivity-wi-fi...
The connection is limited ... He couldn't connect to Wi-fi on battery power. ..... Will this work if we have limited connectivity when trying to connect through a LAN cable? .... I found another solution, If you are running Windows 8 and your laptop keepsdropping the WiFi .... Investigate router or access point issues Failed
Dec 28, 2015 | Tablets & eReaders
My XP laptops cannot connect to my TEW-639GR router over wifi. I get the "Limited or No Connectivity Message". The same 2 XP laptops can connect if they are wired without problems. My Ubuntu...
You can disable the notification so that it would either be on or off only and not a limited connection.
click on start > control panel > network connections
right click on the Local Area Connection > under the general tab, please uncheck the box that says "notify me when this connection has limited or no connectivity" click on ok and then restart the computer.
After the restart, please check the network connection if is still says connected now or it is disconnected. We will check where we can proceed from there.
Mar 25, 2011 | Computers & Internet
How to make youtube videos faster
If you use Windows XP Professional then it is possible to squeeze an extra 20% out of your internet connection. By default Windows XP Pro holds back 20% of your Internet speed for various services like windows update and spyware checks. If you want to tap into this locked speed then make the following changes: • Go to Start-> Run-> and type gpedit.msc • Expand the Administrative Templates branch • Expand the Network tab • Highlight QoS Packet Scheduler • Click on Limit Reservable Bandwidth and check the 'enabled' box • Then Change the Bandwidth limit % to 0 % Once you've done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
goodluck!!!
Feb 21, 2011 | Computers & Internet
I want to conect my hp officejet6210 all in one printer and fax machina
This step-by-step guide describers how to obtain and install HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP drivers for Windows.
1. Define your HP Multifunction device model.
2. Define your operating system to install your HP Multifunction device. Note: Update Drivers in Win Vista
3. Browse Multifunction Drivers.
4. Find HP Multifunction Drivers.
5. Select HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP.
6. Download HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP. Note: you can update all Drivers automatically with RadarSync (Freeware) or DriverScanner (Shareware).
7. Install HP Officejet 6210/6213/6215 All-in-One Basic Software/Driver 4.7.0 Windows 98/ME/2000/XP.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
Sep 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Wifi is saying limited or no connectivity
Hello Rifaaqat,
To start.....
Second...
Good luck.
Dec 30, 2008 | MSI Wind UmNotebook
My computer has no Audio Device. the speakers work fine.
Have you tried Windows Update,
If not follow this:
Click on start --> Programs --> Windows Update and accept all updates.
Windows update scans what your computer has connected to it and will see if there are any out-of-date drivers and software. it will also download them and install them for you automatically.
When this is done, restart the computer and check then if the sound is working.
Dec 28, 2008 | Matrix 226R (VPR226R) PC Desktop
Lan Network Problems
Hello: What I would say is: go to microsoft update and make sure you have all the updates for your OS.
Then; read the posting (below) from someone who had the same issue:
stacemarie wrote: "XP SP 3 updates some networking sharing system LAN files that cause some configurations to become unaccessable on the workgrouped networks. We cannot - even ping - the network addresses after installing - so it was an uninstall and do a system restore to get to the original good working state of the clients.
Microsoft needs to come up with a patch to fix this as we are seeing more and more networked clients having these connection and sharing problems."
Do you understand the above?
Let me know if you do not know how to unistall SP3 and do a Restore...
Jun 24, 2008 | LanReady LA1000+ Network Adapter
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Since those early days of laptop production, Acer has grown to offer devices in every category. From netbooks to high-powered gaming units, there is likely to be a laptop computer made by Acer to fit the needs of just about any consumer. The handy features along with the cool looks make Acer the world leader among the uprising brands also making them the worthy competitors of a large number of brands. Along with the cool style statement suitable for different age groups of customers, Acer products are available at affordable prices, support acer. Amazing features with attractive looks and affordable price range makes Acer brand one of the best choices for laptop users. Even though Acer has created a successful name in the market due to its high efficiency products, acer computer support might come with its share of difficulties which might be faced after a period of time, becoming a source of a lot of trouble for its users. If you are also facing any kind of issue with Acer laptops then, there is no need to worry because we have a team of skilled professionals who will resolve all your issues perfectly without consuming much of your precious time and they can be contact acer support. Issues faced by Acer customers: • Black laptop screen issues • Stretched images on laptop screen issues • Laptop heating up followed by forced shut down • Window update issues • Crashing issues • Windows 10 upgrade problems • Computer Tune up issues • BIOS update Our services for Acer users: Our world class services can be guaranteed to customers once they call on our acer customer service number for assistance regarding Acer products. All your query or issue related to Acer laptops that you want to get resolved in the most efficient way possible will be get dealt by some of the greatest minds in this job with highest levels of experience. Contact our acer technical support team for any assistance regarding issues concerning Acer Laptops by Calling on our Acer customer support number. Get all your trouble sorted out in a matter of few minutes by most courteous and experienced technicians.
Jun 21, 2018 | Acer Computers & Internet
See all MSI Wind UmNotebook Questions
MSI Wind UmNotebook Logo
1,826 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
