Question about Toto Round Washlet S300 Toilet Seat - SW833R
The wand does not spray properly. How do I adjust the wand
I have had a problem with the washlet because if was cleaning the washlet and moved the wand in or out manually and now it does not spray because the holes are not aligned properly. How do I fix this problem. Moving it back to where I thought it was does not help. Any suggestions would be greatly appreciated. I have arthritis and really need the washer to help in the cleaning process.
2 Suggested Answers
muralme
  • 20 Answers
SOURCE: Toto Washlet weak
If you are using well water you might want to upgrade your filtration system.or add a mixing valve to the water supply of your washlet and add a filter there, you answer your own question you have very hard water.So the product is getting abnormal; wear and tear. Without making changes to your water supply you will continue to prematurely go thru fixtures,
Posted on Jul 12, 2009
The wand doesn't go back properly after cleaning , so the water (for the self cleaning of wand) sprays on the walls.
Hey! I had a similar problem with my dishwasher but I couldn't fix it by myself. I am a student and I use dishwasher a lot! I contacted some appliance repair companies, but only this one arrived immediately. here is the link: http://huntingtonbeachappliancesrepair.com/. If you find DIY solution to this problem can you please post it here too?
Many thanks!
Sep 11, 2015 | Dishwashers
Bidet wand malfunction
You may have another malfunction here. Get your manual and see what it says under troubleshooting.
Jan 17, 2013 | Toto Neorest 600 1pc. Toilet MS99OCGR-01
Little water pressure from wand. The pressure does increase and decreasefrom little to nothing and only from one hole.
Try removing tip on wand 9 out of 10 times sand or grit will plug spray orifice
Mar 27, 2017 | Toto Home
I have a Krups Espresso pump XP5240 and as like many people am having problems with the steam wand. The first one disintegrated in the plastic thread area. My new one keeps blowing off when steaming,...
My XP5240 also started blowing the steamer wand off after about 3 months of use, despite fiollowing the Krups cleaning instructions. Here's what I did to fix it.
A: The Problems.
The wand has three holes in the coffee end (center, and on each side). The center hole gets blocked with milk residue. This causes a pressure build up in the wand assembly, and eventually this is enough pressure to overcome the three gripping clips that hold the wand to the nozzle tube. I suspect this was an intentional design for safety. It's unfortunate that it also sprays the user with milk when it lets go.
The second problem is that removing the wand requires that the outer clip retainer ring to be slid down to release the clips. Many users don't realize this and try to pry or twist the wand off. This breaks the clips.
B: The Solution
The wand has to be regularly and throughly cleaned. Just soaking it is not enough. Do it this way:
1. Slide the clip retainer ring down, and then hold the steam tube and gently move the wand straight down. DO NOT try to twist the wand to one side, or you WILL break the clips.
2. Holding the ring, unscrew the coffee nozzle end. The wand separates into three parts: Outer tube, inner steam tube and decorative cylinder.
3. Use a needle or very fine wire (approx 0.4mm) to clear the three holes in the coffee end nozzle.
4. You now need to clear the metal wand tube of milk residue. I found that a 7/64" drill bit was perfect to do this, as it fits snugly in the tube. The amount of gunk removed was surprising.
5. Blow the tube clear from both ends. If it's clean, you will be able to see light through all three holes. If not, go back to step #3.
6. Make sure that there is no milk residue on the steamer tube nozzle where the wand clips on. Milk contains fat, and this is an unwanted lubricant.
After cleaning, my steamer works properly for several days. I also located a 21mm ID O-ring at the local hardware store to hook over the clips. This provides a bit more clip gripping pressure, but will still allow the wand to come off should steam pressure gets excessive.
Aug 02, 2011 | Krups Xp5240 Perfect Tamp Xp5240 Espresso...
The water does not squirt out of the bidet wand
My Toto Washlet has stopped squirting water. Any ideas for fixes?
Dec 02, 2010 | Toto Washlet S400 for Power Gravity...
Toto Washlet weak
Jul 02, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
No water comes out of the wand
First, you must be sitting on it before it will work. Their should be a separate valve for the bidet function, be sure it is turned on. Also check that the seat is installed properly and the quick release "snaps" into place. These are the most common problems if they don't fix it let me know.
Please rate this solution-
Mar 19, 2009 | Toto MS950CG-12 Neorest 500 Elongated One...
Dishwasher- whirlpool (silent partner I )
Sounds like you are not getting water I'd check the water valve first.
Jan 28, 2009 | Whirlpool Dishwashers
Toto Round Washlet S300 Toilet Seat - SW833R Logo
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
