Question about Panasonic PT-53WX54 53" Rear Projection HDTV
Panasonic HD Projection TV PT-53WX54J Linearity Help
The vertical linearity on this TV is out of adjustment. images across the bottom of the screen are quite squashed vertically. Does anyone know how to access the service menu?
I found info on the WX53 series but it does not seem to apply to the WX54.
Thanks, John.
Vertical linearity problem
Check and replace all the electrolytic capacitors at its vertical scan output section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 17, 2014 | Toshiba Televison & Video
Virtical lin
If the problem is with its picture linearity [Vertical], you have to enter its service mode to correct it. It is best to replace all the electrolytic capacitors [5 or 6] of it, at the vertical scan output circuit, before doing any adjustments, because, if there is any of it is damaged, the fault to this kind can occur too. After replacing it, just switch ON the set, and check the picture linearity is correct. If not, enter its service mode, and adjust the vertical picture linearity. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | JVC AV-27D302 27" TV
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Top of screen disappeared...cant see score of game
The Height adjustment is off... look in the back of the TV set, it has some knobs in the back, one should be vert.lin for Vertical Linearity adjustment, and there is another call Vert.Hgt. for Vertical Height adjustment. try adjusting the Vertical Height first with someone watching in the front of the big TV to see if the top comes back into view, you might have to adjust the knob very slowly one way then the other way, to make this adjustment. If it doesnot adjust take it to a TV shop to get it repaired.
Good Luck.
Nov 11, 2010 | Hitachi 57F500 57" Rear Projection...
Vertical line at edge of AV1 channel
hi! he might have adjusted the vertical hold and height including the linearity. normally on the board you would see a trimmer resistor with a label v-hold this is to stop the rolling, v- height for the size of the picture. and linearity for the evenness of the picture from top to bottom.
Aug 28, 2009 | Televison & Video
I have a Panasonic PT-53WX54J that will not Converge
you need to replace or have professional convergence amplifiiers. If know how to desolder and solder you could repair yourself or in home professional tv repairperson will cost you $275-$400. The convergence adjustments via remote are half the battle the IC's loose clarity over time.
Aug 23, 2009 | Panasonic Televison & Video
Picture is stretched on top and bottom of screen
you have a vertical linearity problem. change the vertical output and components.you need a qualified tv technician to solve this problem
Aug 15, 2008 | Emerson EWF2703 27" TV
TV not working properly
You have a vertical problem. See if there are any vertical (height or linearity) controls to adjust. Often there will be screws or knobs on the back.
Otherwise, it could be bad transistor or component in the vertical-deflection circuitry.
Hope this helps. :)
Mar 31, 2008 | Televison & Video
Tube tv problem with picture
There should be controls for height and linearity. They may be labeled as Vertical, Hold or Size.
Hope this helps. :)
Mar 30, 2008 | Televison & Video
Cannot adjust convergence, screen has rainbow effect
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
Dec 28, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX54 53" Rear Projection HDTV Logo
398 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
