Moisture under the headlight cover. want to remove the cover.
SOURCE: how to replace low beam headlight bulb on 1999 chevy malibu
just have a philip screw driver, remove the screw, pull out the light and take the light to the nearst aurozone and they will give you the right light, and put it back the same way.
SOURCE: I need to remove the front headrest of a 2008 chevy cobalt lt
Push the button and pull up on it at the same time
SOURCE: 2008 Equinox Horn Replacement
Hiya
There's 2 horns-one is a low-note pitch on the driver's side and a high-note pitch on the passenger's side.
Both are bolted vertically onto the 'front-under' frame below-behind the headlight area....located just above the steel front interior bumper frame area.
Unplug the black wire from the horn's plug socket.
While you shop for new horns at the store, use the original horn to determine the new horn's plug socket can fit the black wire plug that you took it off from the original horns.
Hope it helps.
SOURCE: change headlight on 2008 Chevrolet Equinox
the chrome trim that goes on center of headlamp has to come off
SOURCE: Change headlight on 2008 Chevy Malibu
Well first you can please follow the below steps -
1. Make sure the ignition key is in the off position and the headlight switch is off. Release the hood latch.
2. Open the hood and locate the top of the headlight assembly where you intend to change the headlight. If a plastic shroud is present, locate the center bolt and remove it with a ratchet and a socket. Lift the shroud out of the way to access the headlight assembly retaining brackets. Some later models may feature a snap-release shroud requiring no tools to remove.
3. Locate the brackets on the top rear of each side of the headlight assembly. Lift them all the way up to align the hole on the bottom of each bracket to the retaining tabs on the assembly.
4. Pull the assembly forward away from the Malibu, but be careful not to scratch the bumper. There are three guide pins that require unseating. The guide pins are what aim the headlights and it may take some wiggling to get the pins from their seats.
5. Support the assembly with one hand and then reach behind the unit with the other. The low beam bulb is on the outside, the high beam bulb is on the inside. You can also replace the parking light if desired. Locate the wire harness connection. Un-clip the wire harness from the back of the bulb socket. Remove the bulb by turning it counterclockwise 1/3 of a turn to align the release tabs of the ring and the assembly. Wiggle the bulb out of the assembly.
6. Place the latex gloves on your hands before opening the package of the replacement bulb. Oil in our skin can damage the glass bulbs of halogen headlights.
7. Carefully insert the new bulb into the ring and then align the tabs of the ring to the tabs of the headlight assembly. Push inward and then twist clockwise 1/3 of a turn to lock the bulb in place. Reattach the wire harness. Rest the headlight assembly inside its cavity and test the operation of the headlight before securing the headlight assembly in place. Be sure to turn the lights and ignition back off.
8. Align the three guide pins to their seats and push the assembly back into them gently until they snap into place. Replace the retaining brackets by pushing them downward to lock into place. Replace shroud, if applicable. Remove the tools and old bulb and close the hood. Post comments for further help or information......
Good Luck!!
