Question about Canon CLC 1000 Color Copier
Clc 1180canon saying paper jam but there is no paper inside
  • khamral BAKSH May 11, 2010
    you have to say where the false jam is located
My be the actuator of paper sensor is hang . look at the sensor where the jam apear
Posted on Dec 31, 2008
Paper jams
first try to clean paper feed rollers in cass.
Jul 27, 2010 | Canon CLC 1120 Color Copier
I have a paper jam on a CLC 1120 and there is no paper jam I've check the machine 10 times
You didn't state where the jam is indicated. If it's indicating a paper pickup jam there are levers toward the back of the cassette that could get hung up.If it's a fuser jam the outlet lever on the fuser unit.If it's indicated in the transfer drum area a bad transfer sheet can give a false jam indication sensing paper on the drum.
May 25, 2010 | Canon CLC 1120 Color Copier
Canon CLC 1140 transfer issue on heavy or extra heavy stock
you must chose the bypass try to copy the heavy paper
Mar 24, 2010 | Canon CLC 1140 Copier
Certain papers, notably a transfer paper that I have used in other machines and have a lot of, will not stick to the drum properly which causes a 'jam' message: "Open front door, remove paper from drum"....
The paper on the CLC-1180 is held to the Transfer Drum by static attraction. Certain papers or media will not work with machine. One thing you can try is to check the flex the paper. Flex the paper and see which way it has the most flex. If the paper has more flex or bend in the Landscape direction load the paper in the Letter "R" direction, or Portrait direction (letter). If the paper is too stiff it will conform to curvature of the transfer drum and Jam.
Canon does not recommend the use of Transfer Material in the CLC series. Canon does have a recommended Heat Transfer Paper for Fabric item # 6094A082AA that will work with the copier.
Canon does recommend aftermarket transfer paper do the damage possible to the fixing rollers. It's possible you could get a Service Tech to adjust the Attraction charge in the copiers service mode to make this paper work better. The CLC 1100 series this very fussy about paper and some papers will just not work. The newer Canon Color copiers use a Transfer Belt which eliminate the bends and provide a straight through paper path much improving the performance with odd or heavy papers.
Mar 01, 2010 | Canon CLC 1180 Copier
sometimes invisible paper jams are cause of teared piece of paper that was left over inside the paper path please check again if there are piece of paper left inside and paper detection switches are ok.
Dec 19, 2009 | Canon CLC 1150 Color Copier
Canon image runner 3200 false paper jam
First check all the tray's and make sure the papersize dial inside the paper cassette is set on the correct papersize,this is the most causes for false paper jams.Open and close all covers machine will send a reset data.Switch the machine off for 3 minutes untill it shows offline on the server and switch back on.
Dec 08, 2009 | Canon Computers & Internet
Canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
Jan 10, 2009 | Canon CLC 1180 Copier
Canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Dec 28, 2008 | Canon CLC 1150 Color Copier
Paper Jammed
your sensor is detach or bad where it says paper jam
Oct 08, 2008 | Canon CLC 1120 Color Copier
Canon clc-700 stops copying when paper sticks to drum
Could be one of two things.
Either the transfer / separation corona wire is dirty / broken, or the separation current is set wrong.
The drum separation claws aren't moving. Possibly a stuck solenoid.
Jan 15, 2008 | Canon CLC-700 Copier
Canon CLC 1000 Color Copier Logo
55 people viewed this question
old marine
old marine
