Question about Kenmore 4292x Front Load Washer
My Kenmore washing machine he3t Model #42932200 is not working....It says 'SUD" I push "drain" and it still won't work
  • jkbelowsky Mar 01, 2009
    washer says f2 or sud any ideas
  • lued_888 Apr 12, 2009
    My wash machine the "Control Locked led light on" it lock up the machine. unplug the power cable waiting for 10 minutes. plug it back the led light still on. please advice.
    Best Regards
    Edward
    lued_888@alive.com
  • 3 Answers
Hopefully you have resolved your problem by now, but in case not, have you tried unplugging the washer for a few minutes and plugging it back in? This should reset the control board. If that doesn't work, its probably a problem with the control board.
Posted on Jan 10, 2009
Leave it alone. You have placed too much soap, or have used a soap that is not HE.
Posted on Feb 03, 2009
I keep getting a sud error during the wash cycle. I have not used too much soap. I have cleaned out the drain, which had some interesting items in it, but this has not fixed the problem
Previous responses posted on fixya.com recommended checking the drain for restrictions. This did fix my "suds" problem, but I had an additional problem with a failed drain pump which may have contributed to the problem.
Aug 17, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
My washing machine gets a sud error often during the cycle. I have cleaned the drain as suggested
Vinegar does a great job of cutting suds and bubbles. I would put it in the detergent, softener, and bleach reservoirs and run a cycle. Then make sure you read the detergent amounts. It's easy to overdo detergent on a front-loader.
HE3T WILL NOT GO INTO SPIN PUMP TAKES A LONG TIME KEEPS SHOWING A CODE OF F02
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Kenmore HE3T Washer
The F02 keeps flashing M#110.42832 CSM#1004028 pls help
Kevin
Feb 09, 2011 | Kenmore HE3T Washer
Kenmore elite hE3 washer has f32 code flashing. Door is locked and would not open.
F/32 error code; this indicates a pressure switch failure. The Sud error code indicates a suds lock condition. Be sure that you are using HE laundry detergent & the drain hose is not too low.
Dec 09, 2010 | Kenmore HE3T Washer
''SUD'' Code on Kenmore Elite HE3t after new pump.
Run some white vinegar through a rinse cycle to get the excess soap flushed out.
Eric
Sep 17, 2009 | Washing Machines
Sud error, door won't open, can't drain water
I was able to fix my washing machine thanks to helpful posts on your website. I didn't realize that the error code reference manual was inside the washing machine. I found the drain filter to be blocked by one of my childs tiny socks. After removing the sock and putting everything back together the machine worked fine. I am grateful that there are websites to help people that are willing to put a little bit of time in to fixing things around the house. I was on the verge of calling a service company to help me.
Thanks again, Medina422
Feb 03, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
Have "sud" code and"f 02" code
I don't have a solution but I feel your pain.
I had an F02 error flashing so I got brave and took off the front panel and opened up the drain thing. What a mess! Water everywhere and OMG,the filter was caked with goop, a popsicle stick and a piece of metal.
I still get a Sud error so I am having the Sears guy out in the morning.
Oct 25, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 4292x Front Load Washer Logo
169 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
