Question about Amana ARGS7650SS Gas Kitchen Range
My amana oven is not heating up
My amana oven is not working the top burners work but oven and broiler do not heat
  • tigerinarmy Jan 04, 2009
    My stovetop and broiler work but the over does not work on bake setting
  • Anonymous Feb 20, 2009
    My stovetop works but the oven does not heat.
reg501
  • 413 Answers
SOURCE: Maytag oven not heating up
The igniter has failed. In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve.($50.00 to $90.00 for igniter). The igniter can get hot enough to raise the temperature 100 to 120 degrees without activating the gas valve.
Posted on Jun 04, 2008
bestdarngood
  • 3037 Answers
SOURCE: Oven does not heat but broiler does
The most common cause of this symptom is a defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately (see the link below).
In that case, replacing the oven ignitor is the usual solution.
http://www.appliance411.com/links/jump.cgi?ID=823
Posted on Mar 22, 2008
SOURCE: Amana Model ARGS7650E Oven Problem
No matter that the igniter glows you must measure the current... If the current is less than 3.2 or 3.6 you must change it (this current is for the igniters with rectangular white base).The current to open the valve is the same that passed through the igniter so if it doesn't reach the proper value it will never open (or sometimes open sometimes not).Mine is not opening and the current is 2.9 so I'm going to replace it tomorrow.
Posted on Dec 26, 2008
  • 63 Answers
SOURCE: The heating element on the bottom of the oven does not work.
lots of those old elements are still out there...some come out with simple pull...or two screws holding the wires!.. take to appliance store (sometimes even lowes!)
Posted on Mar 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
Trouble with an Amana oven
sounds like a bad valve that needs to be replaced. If that doesn't fix it let me know but 90% of the time this is the problem and the fix.
good luck and let me know if you have any other questions with this
Jun 06, 2008 | Amana RanARG7302 Gas Kitchen Range
My oven is not heating up properly, it either doesn't heat up or it takes a very long time to heat up. The range top works fine and the broiler works, but when i set it to bake it doesn't or takes long.
There are two possibilities for problems with the range. If it has a "timed bake" setting for the oven then it's possible that the last person who used it neglected to return the setting to the manual mode. In "timed bake" mode, the oven will heat to approx. 160 - 185 degrees, what is called a "keep warm" temp. It will maintain that heat setting regardless of what you set the oven temp control to, as long as you're not in the time frame that it's set to bake. This will make trying to bake anything a very difficult procedure.
The second possibility is that the oven glo coil igniter is cracked and will not heat to the proper temp to allow the electricity to flow through it to the oven gas safety valve to allow it to open and let the gas flow to the burner. These things are ceramic and for some reason crack in normal use. If it has a top broiler, that unit is obviously good. Unfortunately, the igniters are seldom interchangeable. You would need a tech to check the igniter with an ohmmeter.
Mar 23, 2011 | Amana Ovens
Oven light is on and it is not getting warm...broiler and burners work fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 06, 2011 | Amana Ovens
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My Amana Gas oven does not ignite on the oven side Broiler burners starts
The ignitor is the problem...you will need to replace it...
Here is a tip that will help you..
Oven not Working or Oven not Heating
Heatman101
Mar 01, 2010 | Ovens
Our Electric Amana Self Clean Oven, the broiler is not working? Help! The oven and stove top work just fine, but when we go to turn on the broiler the broiler doesn't come on, the selection buttons all...
canoyu physically inspect teh element for damage, perhaps its broken. or as wireleadingto the rearof elemnt has buntoff. you can check , but turn offpower first, the wires are always live
Feb 21, 2009 | Amana ARGS7650SS Gas Kitchen Range
check the door switch
check the termocouple
hamid
hhamidi56@hotmail.com
Jul 26, 2008 | Amana RanARG7302 Gas Kitchen Range
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
Amana ARGS7650SS Gas Kitchen Range Logo
1,828 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
