Question about Kodak EasyShare One Digital Camera
When I place the camera in the dock, it keeps flashing red
  • 122 Answers
Do you have the right dock? did you try using the cable to down load pics from camera. I had a dock always gave nme trouble either the operating system wasn 't compatible with the dock or the easy share program . solution bought a card reader and got rid of the easy share program .
Posted on Dec 30, 2008
The camera won.t turn on the battery charger blinks red when trying to charge both of my battreies
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Sep 02, 2010 | Kodak EasyShare Z760 Digital Camera
My kodak eastyshare z760 flashes red when on the battery charger but yet, the battery never shows fully charged.
I had the same problem. I needed to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Jun 10, 2010 | Kodak EasyShare Z760 Digital Camera
The dock keeps flashing red while the camera is in the dock
Please note that for the most of the time the Dock will only charge KODAK rechargeble batt. 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 2. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 10, 2010 | Kodak EasyShare CX6445 Digital Camera
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Camera won't charge
Hi!
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Charger blinks red and does not charge
This maybe a solution. I had the same issue just now. Pulled battery, put back in, placed on dock, and still blinking red. So I removed the camera from the dock, pulled battery, put same old battery back in, placed on the dock and turned the mode switch on right away before it started blinkin red. It seems to be charging now with one bar and has not gone blinking red for 15 minutes.
I was outside with the camera in 10 degree weather taking pics of my dogs but had been inside for 20 minutes before placing it on the doc. I think something may have happened with the charging circuit and turning it on right away with it on the doc may have reset the charging. Try it. Hope it works for you.
Oct 23, 2008 | Kodak EasyShare DX6490 Digital Camera
Hp 945 frosen with red light on
I posted on July 16 with this flashing problem and played around and got mine working again.
Originally I would charge through the docking port. What I did was pull the charged rechargable batteries out of the camera and took the charging cable from the docking station and pluged it directly into the port on the side of the camera. The camera started working again. Then while the charging cable was pluged into the camera, I reinstalled the rechargable batteries. After installing the batteries I unpluged the charging cable and the camera still works. I have shot and downloaded from the camera pictures with no more problems. Use the docking for downloading pictures and the side port on the camera for recharging the batteries.
I do not know if this has anything to do with the original problem but I did not have any problems with this camera until I placed it on the docking station with non-rechargible batteries.
Hope this helps.
Jul 02, 2008 | HP Photosmart 945 Digital Camera
Charging Camera
I would test the docking station first. Do you have a way of charging the camera without using the docking station?
Thought I'd ask because some can and some can't.
Jun 21, 2008 | Casio Exilim Card EX-S600 Digital Camera
Red flashing light, constantly.
this is the fix.
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Jun 02, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Docking station
I had the same problem. I did need to take the clear plastic insert off but then I had to put a rubber band around the dock and camera (more on the left of the camera and dock) to hold it evenly on there since the camera was leaning on the right and wasn't charging for me. Now it charges as soon as I put it on there with the rubber band with no blinking red light anymore! Hope this helps!
Mar 23, 2008 | Kodak EasyShare Z760 Digital Camera
Kodak EasyShare One Digital Camera Logo
95 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
