Question about Sony Handycam DCR-HC40E Mini DV Digital Camcorder
LCD Blank My LCD panel is blank it's look like I turn off the backlight but not.when it's blank I still can use the touch screen function. could somebody help me to fixed..? Thanks
  • Anonymous Jan 08, 2008
    lcd screen is blank. it has turned blank only after operating some feature in the menu. however when it is reversed 180 degrees and closed touch screen is functioning.
  • 169 Answers
The flex wire of the lcd monitor is already cut and already left is on the touch screen that why is functioning ...go the sony service for the replacing flex wire...or to the other service center for fixing the flex wire....
Posted on Sep 02, 2007
Tip
Diagnosing a LCD blank screen problem.
Recently a 3 year old VIzio TV I bought started having problems. The set would turn on normally for a few seconds then the picture would go dark with everything else operating normally including sound. Remembering a similar laptop computer problem I diagnosed previously, I immediately suspected a defective TV screen backlight. To verify this in your own TV, get a very bright flashlight and with the TV operating in the failed blank screen mode, shine the flash light into the blank screen from various angles and distance (including touching the screen). If the LCD is still operating, you'll see a dim motion in the flashlight's reflection, thus proving it is indeed a failed backlight.
on Jan 27, 2015 | Televison & Video
Turns on but has a blank screen
Show a torch light on the screen and see whether you can the picture. If yes, the backlight is not getting on. If no, try changing the input device to some other. If you notice same problem, this may need attention by a qualified service technician.
Jul 21, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Blank screen with blue light
Hello
Check the backlight inverter board to your TV. This is a common fault for most of the LCD TVs. If it is faulty, the backlight won't light up, resulting a balck screen with sound.
This is the picture of the backlight inverter board to your TV. OK.12_23_2011_4_29_45_am.jpg
Dec 23, 2011 | Sceptre X400BV-FHD 40 in. LCD TV
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
The touch screen display does not work. It turns on but you cannot give the unit a command through the input panel.
Is the lcd screen completely blank? Or does is it just the touch functionality that is not working?
If the screen is blank, though the copier still turns on and appears to function (test it by printing to it,) then you most likely have a failed power inverter board. This board provides the current needed to operate the lcd screen and is a rather common failure. However, if it is just the touch feature that is not working though the screen lights up, then you most likely have a ripped ribbon cable that connects the lcd touch function to the main board on the lcd screen.
Keep my updated.
David R.
Dec 11, 2010 | Xerox WorkCentre M-24 Color Copier
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Screen turns on when powered up then goes blank.
It sounds like you are having a backlight problem with your computer. The backlight is the part of the LCD assembly that lights up behind the LCD and shines through.
Sep 09, 2009 | Acer Aspire 5610-4491 Notebook
Sony Handycam DCR-HC40E Mini DV Digital Camcorder Logo
324 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
