Question about Whirlpool SF315 Dual Fuel (Electric and Gas) Kitchen Range
Gas smell when oven turned on
When the oven or broiler is first turned on, there is a strong gas smell for a couple minutes. I've watched the ignitor and it comes on immediately after the oven is turned on, but the flame doesn't start up until about 50 seconds after it is started. The installation manual says that 20-40 seconds is normal. Is this slight delay of about 10 seconds causing gas to escape during the ignition phase? If so, is there a valve that releases gas to the oven that is doing so prematurely? Not sure what to fix here.
  • Rustyh Nov 06, 2007
    My oven won't go on.
    The pilot is on and when I turn on my oven the pilot gets a little larger but does not light the log. (I can't light the log even with a lighter, it appears that the gas is not getting to the log?)
    Novelist:
  • 114 Answers
CALL THE GAS COMPANY AND TELL THEM YOU SMELL GAS ... SOME GAS COMPANIES STILL COME OUT FOR FREE TO CHECK. DO NOT TELL HIM A BUNCH OF DETAILS. JUST THAT YOU SMELL GAS AT THE STOVE. CHANCES ARE YOU WILL GET A NICE GUY WHO MAY TELL YOU EXACTLY WHATS WRONG AND FIX IT. EVEN IF THEY CHARGE YOU CAN PAY THEM IN SMALL AMOUNTS EACH MOTH FOR THE BILL. 50 SECONDS IS TOO LONG ...THE 20-40 SECONDS ALLOWS FOR THE SLOW STEADY INCREASE OF GAS FLOW TO START ... TO AVOID THE GAS COMMING ON AT FULL PREASURE AND CAUSING A "HARD IGNITION" OF THE BURNERS. THE GAP AND THE CORECT DISTANCE OF THE LOCATION OF THE IGNITOR TO THE BURNERS SHOULD BE CHECKED.THIS GAP IS USUALLY IN THE SPEC. MANUAL. ALSO MAKE SURE THE FLAME SENSOR IS IN THE FLAME. FOR THE FACT YOU SAY THIS IS HAPPENING TO BOTH UPPER AND LOWER BURNERS LEAVES ME TO THINK THE GAS PRESSURE IS NOT CORRECT GOING INTO THE APPLIANCE ... THE GAS COMPANY WILL CORRECT THAT. GOOD LUCK AND BE SAFE !!!! Joe_Rex
Posted on May 02, 2007
Magic Chef oven won't lite. The ignitor glows red hot but no flame. After about 10 minutes of being on I start to smell gas. Not a strong smell but its in the air. I'm thinking gas valve. I did a...
The problem with your oven is that ignitor is weak and not drawing enough amprage to open the gas valve, the gas you smell was since the ignitor does come on it allowed the gas valve to open a wee bit but since ignitor is weak it wont allow gas valve to open fully. I know you going to doubt that what i'm telling you is correct, i base my diagnosis on my 30 years experience as a appliance repair technician.Replace ignitor and enjoy your baked meal
Gene
Jul 30, 2011 | Magic Chef 9122 Gas Single Oven
Smell gas
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
bbv
Jul 30, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Gas smell coming from oven during preheat. once oven is warmed up, smell goes away. I have a Frigidaire FGF366EBC S/N VF6289284.What would cause this?
Typically, all gas operated appliances will get a "gas smell" from time to time. What you're really smelling is the odorant (rotten egg smell) that is added into both propane and natural gas, as these gases have no smell by themselves.
The smell will vary from normal to very strong as the "receipe" for how much ordorant is added into either your propane tanks or the gas supplied to your home. Typically, when tanks start getting low, the smell is more concentrated, while with piped natural gas, the smell can be very strong at different times, based on how and when the gas company adds odorant into the main supply lines.
Usually when a gas appliance is first turned on, the smell can be rather strong, until the gas ignites. So long as your oven is lighting properly, there is nothing to worry about.
However, if you're hearing a rather loud "whoosh" sound as the oven lights, it could be that your ignitor is getting weak and might need to be replaced. If you've got a weak ignitor, it could be allowing a little bit too much gas to build up in the oven compartment before it lights, hence the reason you're smelling the gas.
You can check for a weak ignitor by simply watching the oven when you start it, if the gas lights quickly, once the ignitor is glowing brightly and you've heard the "click" of the gas valve opening (in the oven), then everything is fine.
Hope you find this Very Helpful and best regards!
Sep 10, 2009 | Kitchen Ranges
MY BROIL ELEMENT WON'T IGNITE ON MY MGS5870ADW MATAG GAS RANGE AND I DON'T KNOW WHAT PART TO ORDER. BACK ELEMENT OR IGNITER IS GLOWING RED.
It could be that the ignitor is weak and only partially heating which could be causing the gas control valve not to open and allowing the gas to flow into the broiler burner tube.
I would also suggest you see if you can smell gas to confirm that the gas supply valve is actually opening up. With the oven door closed, turn on the broiler and after 20-30 seconds of having the ignitor glowing red, turn off the broiler control and open the door and see if you can smell gas, if not it could be either a weak ignitor or a faulty gas control valve.
I would suggest that before you start ordering parts, you swap out the oven ignitor with the broiler ignitor to verify that the broiler ignitor is the problem. It could also be the broiler tube has a blockage of some sort possibly from cooking debris, that is preventing gas from flowing into the tube.
Here's a diagram for your unit along with the parts list.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MGS5870ADW&productCategoryId=0124250&brandId=3048&modelName=MAYTAG-COOKING&diagramPageId=00005&componentDescription=GAS%20CONTROLS&documentId=M0412019&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this very helpful and best regards!
Aug 07, 2009 | Ovens
GE Profile gas range - stove works, oven doesn't heat
Set the oven for bake. Wait a couple minutes and look in the oven. If you see a orange glow the ignitor is working, but, may need to be replaced.
If you see no orange glow the ignitor definitely needs to be replaced.
Feb 20, 2009 | Kitchen Ranges
Gas leaks into oven when i turn on the broiler
You have what we called delay ignition. may be the broiler ignitor too far away from broiler, partially clogged broiler orifice or bad ignitor, I"ll check the Amperage on the ignitor, it should draw above 3 AMPs, if not, then I'll change the ignitor first then check the orifice. Have fun.
Dec 04, 2008 | Dynasty DGRSC 36-4CB Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Oven burner doesn't light
If memory serves me,there are a couple of screws on oven floor.Remove panel.Sounds like ignitor is the culprit.It feeds back to control.It may glow and light but unless it is sending full signal,gas valve will not open fully and oven will take forever to heat.
Jan 01, 2007 | Maytag MGS5870 Gas Kitchen Range
Open Questions:
Whirlpool SF315 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,461 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
